Trying to  install the MAME system pack. I get an "Invalid ROM Path" error from the system pack installer. I triple checked the path to my MAME ROMs and it is legit. I even copy and pasted the ROM path from the Mame settings page in the GameEX Arcade setup wizard. Didn't work. The rom path works fine in GameEx. Games load.
Stumped.
Do you have a full rom set? The installer assumes this is the case. There was a similar posting by another user a short time ago here.
Make sure 005.zip exists in your set. If not, either remedy that or add a dummy copy and try again.
According to the utility you are missing some files, namely 005.zip. This is what the utility checks for to validate a proper mame set and as RedDog said just create 1 in the folder.
