So I've begun using GE Arcade rather than GE (for the time being) and have some questions:
Do I need to enable the Slikstic and IPAC option in the setup wizard as I'm using an IPAC-4?
I've enable the CPWizard in the setup wizard but when I go into a game it doesn't display the panel image like it did in GE. It also isn't showing up in the in-game options list. CPWizard is sitting in my task bar as running - not sure if this is correct? I've setup my panel properly in CPWiz and made it the default panel and the CPWiz testing showed it was all working.
I'm trying to use the panel buttons for controlling GE Arcade and for the most part it works - joystick moves the lists up and down, Player 1 start (Keyboard_1) works as the enter button (although I didn't set it) however I'm not sure which button goes back a menu? Pressing the ESC button on keyboard closes GE Arcade, so in the setup wizard I selected my Player 1 coin (Keyboard_5) as the back button. That worked fine in GE Arcade, so able to use joystick to navigate, start to select, coin to go back, however when I go into a game and press coin, the game quits and goes back to GE Arcade so clearly GE Arcade is still "monitoring" the button presses. I don't want to have a dedicated to go back and would like to use the buttons I have. Any way to have GE Arcade not still have control even though I'm in a game?
Cheers
-cdbrown
