KRC Posted September 25, 2017 Share Posted September 25, 2017 Hey Fellas, I remember a while ago a few members including myself speaking about Retro Achievements. http://retroachievements.org Does anyone still use these emulators? The Retro Achievements Forums are still very active so it must be a good thing. I'm in the process of adding these as extra emulators. I did set these up a couple of years ago but never got round to actually using them. Quote Link to comment Share on other sites More sharing options...
Adultery Posted September 25, 2017 Share Posted September 25, 2017 I use RetroArch for RA. You don't need their emulators unless you're authoring. You do need specific cores though. If you wanna know what cores to use, here are my suggestions: FCEumm for NES (Rumor is QuickNES also works, but not for Android which is where I mostly play) PicoDrive for SMS, GG, GEN, SCD Beetle PCE Fast for PCE Mupen for 64 (I think, not 100% sure) SNES9x 2010 for SNES Let me know if you have questions but the setup is pretty easy. 1 Quote Link to comment Share on other sites More sharing options...
hansolo77 Posted September 25, 2017 Share Posted September 25, 2017 I'm still very active there as well. I've not set up anything for GameEx yet, just my NESPI. Quote Link to comment Share on other sites More sharing options...
KRC Posted September 25, 2017 Author Share Posted September 25, 2017 Im going to give it a shot now and see how I go, hopefully easily enough,if not I'll let you know. Quote Link to comment Share on other sites More sharing options...
DazzleHP Posted September 26, 2017 Share Posted September 26, 2017 RetroArch is built for ease of use, I'd be surprised if you had any problem with it. Quote Link to comment Share on other sites More sharing options...
Adultery Posted September 26, 2017 Share Posted September 26, 2017 Same. I had to switch some cores around for my GameEx rig, but was already using RA for my emulators anyway so I can have a custom bezel. The effort was minimal. Quote Link to comment Share on other sites More sharing options...
hansolo77 Posted September 27, 2017 Share Posted September 27, 2017 Don't forget to add me to your friends list! http://retroachievements.org/user/hansolo77 Quote Link to comment Share on other sites More sharing options...
Adultery Posted September 27, 2017 Share Posted September 27, 2017 Indeed!! http://retroachievements.org/user/Adultery Quote Link to comment Share on other sites More sharing options...
KRC Posted September 27, 2017 Author Share Posted September 27, 2017 So I setup RAgens from Retro Achievements and ran it, it works no problem with achievements popping. Gens options are quite poor though compared to Fusion. Also had to extract all the Zip Files in my games folder as I think Gens doesn't read Zip or Rar files. Just need to implement them into GameEx now which I will do later. http://retroachievements.org/user/KRC1 Quote Link to comment Share on other sites More sharing options...
Adultery Posted September 27, 2017 Share Posted September 27, 2017 You should check out the PicoDrive core, no unzip needed. Quote Link to comment Share on other sites More sharing options...
KRC Posted September 28, 2017 Author Share Posted September 28, 2017 17 hours ago, Adultery said: You should check out the PicoDrive core, no unzip needed. Will do! Quote Link to comment Share on other sites More sharing options...
