Gameex 14.90 Mame Games Running via Rocketlauncher
Tom,
Since the latest version of Gameex forces MAME games to be run using Mame without the ability use Rocketlauncher via the AdvanceMame options (now gone from Setup Wizard), I have been using the mameeumumap config file to tell Gameex to use an other emulator to run mame roms.    I have edited the config file as such:
[GENERAL]
# Enable this feature in GameEx and use this file
Enabled=true
# You may not want to list an emulator specified seperatly
# in the GameEx menus
# and make this feature transparent.
# Specify Emulator Numbers seperated by | to hide and use only for MAME
Hide=0
# Some emulators need the full filename of the rom. ie with the .zip extension
# Specify emulators where the extension should be used seperated by |
Ext=
# If you want roms for a specific driver to always be visible in the list
# and override any other filters, such as when you dont have the MAME rom
# specify the drivers seperated by |
Driver=
# The following settings tell GameEx when to use an emulator to launch
# instead of MAME. To specifcally specify MAME use 0. To specify Daphne
# use 1000
# Example Launches 1942 rom with emulator 10:
1942=3
1943=3
1944=3
19XX=3
Thus these few games are forced to use emulator 3.  However, I want ALL mame roms to run via emulator 3.
Do I have to enumerate all my roms separately, or is there some wildcard I can use to tell mameemumap to run ALL roms via emulator 3
Does this mean that the Advancemame options in the ini will override the embedded mame launching functions and therefore launch Rocketlauncher rather than mame.exe??
