Hi,  just setup Pinballx and everything in general is working great....really great app!!!
Two small issues(for me) that I'd like to know if there's a workaround/setting.  (Im using Windows 10)
1>  Default Mouse Pointer is changed by Pinballx.   Just going into and exiting PinballX will cause the default pointer to revert to default arrow...  For most that probably isn't an issue, but is there a way to disable this or set the mouse cursor pointer it uses?  (ex.  If I set windows default pointer to just a dot,  when I leave pinballx....it is set back to an arrow)
2>  when running a Virtual Pinball X table,  everything works...  but for 7-8 seconds the mouse is 'possessed' (no one would see it unless they move their mouse)....  if you try and move the mouse during the first 8 seconds...it will jump back and forth.  I think I saw that it has to do with keeping VPX in focus or something like that...  is that configurable?  If i change VPX to a custom interface will that 'feature' be disabled?
thanks...
