I'm having a issue with setting up my Future Pinball in PBX. When i select the table it will start loading, but the PinballX game select screen comes back up on my playfield after a few moments and the Future Pinball table loads in the background. If i Alt+Tab or exit PBX, the FP table is loaded and playable underneath. The game select screen is popping back up when Future pinball goes to the Playfield loading splash screen where it initializes the tables. Any help will be greatly appreciated. It does the same thing when loading just FP or when using BAM, I've tried it both ways already.
This is what it is doing =
This is my PinballX.ini configuration
[Display]
Monitor=0
rotate=270
Windowed=False
WindowWidth=480
WindowHeight=720
WindowX=0
WindowY=65
PlayFieldBrightness=230
WheelTextColor=ffffffff
InfoTextColor=ffffffff
InfoTextOutlineColor=ff000000
FilterTextColor=ffffffff
MenuColor=ffffa500
ShowExitImageFor=4
[BackGlass]
monitor=1
x=0
y=0
width=1280
height=1024
AutoPositionB2S=True
[DMD]
Enabled=False
monitor=2
x=0
y=0
width=1280
height=1024
AutoPositionPinMAME=False
[FileSystem]
EnableFileMatching=True
[Interface]
DesktopModeEnabled=False
EnableAdditionalDetail=True
ShowSystem=True
ShowRatings=True
[Audio]
StreamVolume=90
SampleVolume=90
PlaySoundInVideos=True
[Startup]
playsound=True
playvideo=False
StartWithWindows=No
[KeyCodes]
quit=27
left=37
right=39
select=13
rotate=82
pageleft=33
pageright=34
exitemulator=69
ingame=80
screenshot=83
screenshotbackglass=66
instructions=73
volumedown=109
volumeup=107
credit=53
plunger=164
[JoyCodes]
quit=10
left=0
right=1
select=2
rotate=3
pageleft=4
pageright=5
exitemulator=6
ingame=13
instructions=14
[Text]
Line1=Free Play
Line2=Press Start
Featuring=Featuring
Tables=Tables
PlayGame=Play Game
Instructions=Instructions
Information=Information
Flyer=Flyer
Gameplay=Gameplay
Tutorial=Tutorial
ExitGame=Exit Game
ReturnToGame=Return to Game
Return=Return
Exit=Exit
Shutdown=Shutdown
[FuturePinball]
WorkingPath=C:\Future Pinball\
TablePath=C:\Future Pinball\Tables
Executable=Future Pinball.exe
Parameters=/STAYINRAM /open "[TABLEPATH]\[TABLEFILE]" /play /exit
LaunchBeforeEnabled=False
LaunchBeforeWorkingPath=
LaunchBeforeExecutable=
LaunchBeforeHideWindow=False
LaunchBeforeWaitForExit=True
LaunchAfterEnabled=False
LaunchAfterWorkingPath=
LaunchAfterHideWindow=False
LaunchAfterWaitForExit=True
MouseClickFocus=True
FPRAMPath=C:\Future Pinball\fpRAM
[VisualPinball]
WorkingPath=C:\Visual Pinball
Executable=VPinball993.exe
LaunchBeforeEnabled=false
AutoConfigure=False
[ExitScreen]
EnableExit=True
EnableShutdown=True
ConfirmExitGameTimer=True
[StartupProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=true
WaitForExit=false
[ExitProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=False
WaitForExit=
[AttractMode]
Timer=1
ShowFor=15
MuteAudio=False
[System_1]
Name=MAME
Enabled=False
TablePath=C:\
Executable=mamep64.exe
Parameters=[TABLEFILE]
SystemType=0
[AutoExit]
Enabled=False
Minutes=10
[Login]
Enabled=False
[PinballFX2]
Enabled=False
Executable=steam.exe
Parameters=-applaunch 226980 [TABLEFILE]
Process=Pinball FX2.exe
Rotate=False
WaitFor=20
[Internal]
lastwheelcachematchsize=-1123
lastselected=The JetsonsThe Jetsons.fptFuturePinball
filter_year=
filter_company=
filter_custom=
filtername=Tables
[PinballArcade]
Parameters=-applaunch 238260
Process=PinballArcade.exe
WaitForSelect=50
[GameListManager]
onlinemode=false
[RealDMD]
EnableColor=True
Color=ffff1414
[SetupWizard]
EmuPath1=C:\Emulators
AssetPath1=C:\Assets
RomPath1=C:\Roms
DefaultPathPrompt=True
DownloadDatabasePrompt=True
DownloadEmulatorPrompt=True
WizardMode=2
CustomArray=Future Pinball
SearchArray=
SavePosition=False
SectionIndex=21
SearchText=
EmulatorIndex=0
EmulatorGroupIndex=0
DaphneIndex=0
HTMLAppsIndex=0
ExternalAppsIndex=0
RadioStationsIndex=0
NewsFeedsIndex=0
MappedDrivesIndex=0
SystemIndex=0
ShowPanel=True
FontSize=1
WindowState=0
WindowSize=654,1031
WindowLocation=1835,0
[Topper]
monitor=2
Here is the Log File=
20:36:21.0  6/11/2017:  PinballX - Version 2.36
20:36:21.1  6/11/2017:  Windows 10 Home 64-bit (7.9GB)
20:36:21.1  6/11/2017:  Loading Settings
20:36:21.1  6/11/2017:  Initialize Component
20:36:21.2  6/11/2017:  Initialize Display
20:36:22.3  6/11/2017:  Loading PlugIns
20:36:24.1  6/11/2017:  Created DirectX BackGlass Window
20:36:24.3  6/11/2017:  Hiding Cursor
20:36:24.3  6/11/2017:  Hiding Taskbar
20:36:24.4  6/11/2017:  CPU:  AMD Phenom(tm) II X4 810 Processor
20:36:24.4  6/11/2017:  GPU 1: NVIDIA GeForce GTX 650 Ti
20:36:24.4  6/11/2017:  Displays: 2
20:36:24.4  6/11/2017:  Load Game List
20:36:24.4  6/11/2017:  Loading Database: Future Pinball
20:36:24.4  6/11/2017:  Loading Database: Visual Pinball
20:36:24.5  6/11/2017:  Finding and matching artwork and videos
20:36:25.0  6/11/2017:  Loading Game Statistics and Scores
20:36:25.5  6/11/2017:  Loading Surfaces
20:36:25.8  6/11/2017:  Finished Loading Surfaces
20:36:25.8  6/11/2017:  Initialize Audio
20:36:25.9  6/11/2017:  Set Keyboard Controls
20:36:25.9  6/11/2017:  Initialize Joystick
20:36:25.9  6/11/2017:  1 Joystick Attached
20:36:25.9  6/11/2017:  Started
20:36:45.7  6/11/2017:  Launch System
20:36:45.8  6/11/2017:  Waiting for threads
20:36:45.8  6/11/2017:  Disposing display
20:36:47.7  6/11/2017:  C:\Future Pinball\\Future Pinball.exe /STAYINRAM /open "C:\Future Pinball\Tables\Gremlins.fpt" /play /exit
20:36:55.0  6/11/2017:  Access is denied
20:36:55.0  6/11/2017:     at System.Diagnostics.ProcessManager.OpenProcess(Int32 processId, Int32 access, Boolean throwIfExited)
20:36:55.0  6/11/2017:     at System.Diagnostics.Process.GetProcessHandle(Int32 access, Boolean throwIfExited)
20:36:55.0  6/11/2017:     at System.Diagnostics.Process.get_HasExited()
20:36:55.0  6/11/2017:     at PinballX.Main.q()
20:36:56.0  6/11/2017:  Created DirectX BackGlass Window
20:37:14.5  6/11/2017:  Exiting
20:37:14.5  6/11/2017:  Showing Taskbar
20:37:14.6  6/11/2017:  Unhiding Mouse Cursor
20:37:14.6  6/11/2017:  Disposing Plugins
20:37:14.6  6/11/2017:  Saving Settings
20:37:14.6  6/11/2017:  Bye
Thanks Outhere that did the trick, now i'm having a new issue it launches the table but now i have to click the playfield with the mouse before it lets me play. like it's showing on top now but still isn't the active window.
try this
You may have to run some or all of the exe as administrator in order to do that right-click the file, click
 properties then click on the compatibility tab and run program as administrator
Thanks for the suggestion, I'm running everything as Admin and I also have unblocked all .dll files for both FP and PBX but still seem to be having the click issue. At least it works now, I can always map a button to click the playfield and hide it bellow the cab if I have to. Don't really want to but that's something I can live with if I can't figure it out.
