I've got two .kar files but gameex karaoke don't find them.
Where do I put them for play ? Where do I find about karaoke configuration ?
I just installed karaoke for directx too. (gameex 6.46)
Thank you
pminera
Thank you
pminera
Assuming you've got a registered version of GameEx you set the location for Karaoke files in the configuration application under Multimeida/HTPC Settings. Then make sure your files are in the path.
I set video dir (c:\) and I put .kar files but nothing (karaoke: not music found).
Can you help me about set for gameex to find .kar files?
windows media player 11 have no problem with .kar files...
Can you help me?
Thank you
pminera
Can you help me?
Thank you
pminera
Ah I forget ... my gameex version 6.47 reg.
Can you help me?
Thank you
pminera
Sorry, my bad. Its not under Multimedia/HTPC settings, there's actually a Karaoke settings. Change the path in that section. You might need to click next page to get to it.
Excuse me, but I don't find any Karaoke settings in the configuration....
Where can I set the path for .kar files ? What's the configuration section where can I find it ?
Thank you
pminera
You have to have a registered version of GameEx to use the Karaoke feature. Have you registered GameEx (ie. Received the key and applied it)?
Also it would make sense to put the karaoke files into a directory rather than the root of C:, perhaps something like C:\Karaoke?
Thank you
pminera
It's there in the configuration application. As I said you may have to click "NEXT" and maybe more than once.
Ok I find it. I set the path and I put .kar files.
I've another problem : no sound from karaoke applications with .kar files (text ok)
Media player 11 works fine with .kar files.
Jukebox audio ok but not karaoke audio.
Where can I set karaoke audio for .kar files ?
Can you help me?
Thank you
pminera
