When I boot my computer Gamex is set to load on startup. But it fails to load correctly some of the time. I can close out the error log and double click on the gameex icon and it loads fine. Anybody have any idea why it won't load correctly when the computer boots up?
21:49:19.0 7/11/2006: GameEx: Version 6.46: Starting Log
21:49:19.0 7/11/2006: Operating System Platform: Win32NT
21:49:19.0 7/11/2006: Operating System Name: Windows XP
21:49:19.0 7/11/2006: Operating System Version: 5.1.2600
21:49:19.0 7/11/2006: Checking for versions of .net Framework installed
21:49:19.0 7/11/2006: .net Framework 1.1 Installed
21:49:19.0 7/11/2006: .net Framework 2.0 Installed
21:49:19.0 7/11/2006: Checking Registration
21:49:19.0 7/11/2006: Running Randomize()
21:49:19.0 7/11/2006: Checking for applications to Launch On Startup
21:49:19.0 7/11/2006: Initialising Video/MNG DLL's
21:49:19.0 7/11/2006: Running Misc startup tasks
21:49:19.0 7/11/2006: Setting Menu types
21:49:19.0 7/11/2006: Opening Configuration File
21:49:19.0 7/11/2006: Getting Configuration Values
21:49:19.0 7/11/2006: Using Theme: Default - Custom V2 Default 800x600
21:49:19.0 7/11/2006: Checking for alternate Image Directory for Theme: Default - Custom V2 Default 800x600
21:49:19.0 7/11/2006: Launching HideOS.exe
21:49:19.8 7/11/2006: Hiding Taskbar
21:49:19.8 7/11/2006: Is Media Center running?
21:49:19.8 7/11/2006: Checking/Creating LCD Registry values
21:49:19.8 7/11/2006: Check Media Center Exit/Start Mode
21:49:19.8 7/11/2006: Media Center Mode 0
21:49:19.8 7/11/2006: Text/Language: English
21:49:19.8 7/11/2006: Applying Language/Text
21:49:19.9 7/11/2006: Custom Keyboard Input enabled: Getting custom codes
21:49:19.9 7/11/2006: Snap Delay set to: 5
21:49:19.9 7/11/2006: Get other settings
21:49:19.9 7/11/2006: SlikStik support enabled
21:49:19.9 7/11/2006: Using DirectInput for keyboard input
21:49:19.9 7/11/2006: Start work for Form
21:49:19.9 7/11/2006: Getting Original Screen Size
21:49:19.9 7/11/2006: Loading ICON
21:49:19.9 7/11/2006: Initializing Component
21:49:19.9 7/11/2006: Initialising Bass Audio Library
21:49:20.1 7/11/2006: Loading default loading screen
21:49:20.1 7/11/2006: Version 2 Theme being used. Loading.
21:49:20.1 7/11/2006: Loading Button Data
21:49:20.1 7/11/2006: Loading Font Data
21:49:20.1 7/11/2006: Loading Layout Data
21:49:20.1 7/11/2006: Loading Taskbar Data
21:49:20.1 7/11/2006: Using 3D Alpha Blended Animations. This could be slow
21:49:20.1 7/11/2006: Using General Font: Trebuchet MS
21:49:20.1 7/11/2006: Using Title Font: Trebuchet MS
21:49:20.1 7/11/2006: Starting GameExtender on: 127.0.0.1:8383
21:49:20.1 7/11/2006: Starting GameExtender Publisher
21:49:20.1 7/11/2006: Initialising DirectDraw
21:49:20.2 7/11/2006: Applying GameEx is Loading Image
21:49:20.2 7/11/2006: Creating DirectDraw Device
21:49:20.2 7/11/2006: Using Device: XGI Volari Family
21:49:20.3 7/11/2006: Setting Resolution to 800x600 16 bit color
21:49:20.3 7/11/2006: Creating DirectDraw Surfaces
21:49:20.3 7/11/2006: Creating Primary Surface - Full Screen Mode
21:49:20.3 7/11/2006: Creating Back Buffer
21:49:20.3 7/11/2006: Loading graphic surfaces
21:49:20.3 7/11/2006: Creating Surfaces Misc and Dialogs
21:49:20.4 7/11/2006: Creating Surface Volume
21:49:20.4 7/11/2006: Creating Surfaces Arrows
21:49:20.4 7/11/2006: Creating Surfaces GameEXlogo Text
21:49:20.4 7/11/2006: Creating Surfaces Toolbar
21:49:20.4 7/11/2006: Creating Surfaces Backgrounds
21:49:21.0 7/11/2006: Creating Surfaces Toolbar Controls
21:49:21.1 7/11/2006: Creating Surfaces GameEx Logo
21:49:21.1 7/11/2006: Creating Surfaces Home & Exit
21:49:21.2 7/11/2006: Creating Surfaces Snaps
21:49:21.2 7/11/2006: Creating Surfaces Menu and List Bars
21:49:21.4 7/11/2006: Creating Fonts
21:49:21.4 7/11/2006: Creating Menu Font
21:49:21.5 7/11/2006: Creating Game Font
21:49:21.6 7/11/2006: Creating Game Font Standard Size
21:49:22.6 7/11/2006: Creating Font Black
21:49:22.7 7/11/2006: Creating Font Black Small
21:49:22.8 7/11/2006: Creating Game Font Faded
21:49:22.9 7/11/2006: Creating Title Font
21:49:23.3 7/11/2006: Creating Control Panel Font
21:49:24.2 7/11/2006: Fonts Created Succesfully
21:49:24.2 7/11/2006: MAME Path is: D:\MAME
21:49:24.2 7/11/2006: MAME EXE file is: Mame32.exe
21:49:24.2 7/11/2006: ROM Path is: D:\MAME\roms
21:49:24.3 7/11/2006: Catver.ini is located at: D:\MAME\catver.ini
21:49:24.3 7/11/2006: controls.ini is located at: D:\MAME\controls.ini
21:49:24.3 7/11/2006: History.dat is located at: D:\MAME\history.dat
21:49:24.3 7/11/2006: nplayers.ini is located at: D:\MAME\nplayers.ini
21:49:24.3 7/11/2006: MAMEinfo.dat is located at: D:\MAME\mameinfo.dat
21:49:25.0 7/11/2006: Loading Controls.ini map file
21:49:25.0 7/11/2006: Loading Custom Emulators
21:49:25.0 7/11/2006: Loading Emulator 1: Nintendo Enertainment System
21:49:25.0 7/11/2006: Loading Emulator 2: Super Nintendo
21:49:25.0 7/11/2006: Loading Emulator 3: Sega Genesis
21:49:25.1 7/11/2006: Loading Emulator 4: Sega Game Gear
21:49:25.1 7/11/2006: Loading Emulator 5: Atari 2600 Games
21:49:25.2 7/11/2006: Loading Emulator 7: Pinball Games
21:49:25.4 7/11/2006: Snap Path is: D:\MAME\snap
21:49:25.4 7/11/2006: AVI Snap Path is: c:\videos
21:49:25.4 7/11/2006: Flyer Path is: D:\MAME\flyers
21:49:25.4 7/11/2006: Cabinet Path is: D:\MAME\cabinets
21:49:25.4 7/11/2006: Title Path is: D:\MAME\titles
21:49:25.4 7/11/2006: Panel Path is: D:\MAME\cpanel
21:49:25.4 7/11/2006: Icon Path is: D:\MAME\icons
21:49:25.4 7/11/2006: Marquee Path is: D:\MAME\marquees
21:49:25.4 7/11/2006: MAME CMD options: -triplebuffer -nowindow -joy
21:49:25.4 7/11/2006: Attempting to load game list
21:49:25.5 7/11/2006: Loading last used Game List
21:49:25.5 7/11/2006: Loading Start Page
21:49:25.5 7/11/2006: Setting Music Volume
21:49:25.5 7/11/2006: Creating DirectSound Device
21:49:25.5 7/11/2006: Trying: Primary Sound Driver
21:49:25.6 7/11/2006: Loading Sound Files
21:49:25.6 7/11/2006: DirectSound Device Created Successfully
21:49:25.6 7/11/2006: Creating ICONS
21:49:25.6 7/11/2006: Restoring Cached ICONS from File
21:49:25.7 7/11/2006: Gamepad/Joystick disabled
21:49:25.7 7/11/2006: Initialising DirectInput for Keyboard support
21:49:25.9 7/11/2006: Playing intro sound file
21:49:25.9 7/11/2006: Initializing MCE Remote
21:49:25.9 7/11/2006: Initialization OK! Starting GameEx!
21:49:25.9 7/11/2006: Testing Main Loop Once: Processing Frame
21:49:26.1 7/11/2006: ERRORS DETECTED: EXITING
So your saying it dosn't happen all of the time? Have you got GameEx loading at startup from using Tom's Instant Sheller? If this is the case perhaps a particular driver is not getting loaded properly at startup. Try restoring the shell back using Instant Sheller and place a link to GameEx in the Startup folder (Start->Programs->Startup) and see if it's booting okay that way.
