Has anyone experienced choppy or intermittent sound when playing MAME games with the "Run in a window" setting unchecked.
I've fiddled with a number of settings, and seem to have narrowed it down to this setting causing the problem.
I know it seems a bit odd that a display feature is affecting sound, but it is repeatable on my setup.
I'd prefer to play in fullscreen - does anyone have a solution?
Anyone have any ideas?
Actually I think its quite a common thing for the display settings to mess up the sound. This was always an issue when Triple Buffer was turned on for me on a bunch of different machines. The solution was to turn off triple buffering or alternatively change the sound latency and sample rate. I always did the latter. I never noticed any degrading of the sound when doing that. Also I think the MAME32FX build of MAME gets rid of these kind of issues, as I believe its main purpose is improved sound. Its the build I tend to use anyway.
OK, I'll try that, thanks. :-)
Thanks Tom - turning off triple buffering did the trick :-)
You're obviously very knowledgeable about MAME - maybe you could help with my MCE Keyboard problem? It works fine in MAME32, but isn't recognised once a game has been launched. I've worked around this by configuring all the game commands to my gamepad, but still have to use a PS/2 keyboard to press the [ESC] key to quit a game.
If there was a way to assign [ESC] or "quit game" to a gamepad button I could do away with the PS/2 keyboard which would be great.
Any suggestions would be very much appreciated.
