Thanks,
Can you tell me where you set the folder for this, ie what's the folder called/logos/wheelart/marquees that is used for the wheel?
Thanks again,
Steve
I am not sure that we are in the same page....so...
You can define a folder for the marquees in the Mame Settings under Marquee path in the Setup Wizard. If the marquee path field in this section is left blank, GameEx will use the marquees GameEx Arcade Edition\MEDIA\DOWNLOADED ARTWORK\MAME\MARQUEE.
But, if you are talking about the graphics that are actually used ON THE WHEEL, these are Logos. A logo path can also be defined in the Mame Settings section. If the field is left blank, GameEx will use the Logos in GameEx Arcade Edition\MEDIA\DOWNLOADED ARTWORK\MAME\LOGO.
Hopefully one of these is what you need.  :)
