Anybody ever had an issue with Southpark vpx backglass not showing in PBX?
This is what i've tried.
Table named the same as db2s
Db2s named as the rom
hide backglass unchecked in game manager
tried different downloads of the table and the backglass
All with the same results, any ideas?
Not showing when browsing tables or after starting the table from pinballx?
Dow the b2s show up if you play table directly from vpx?
Yep shows up fine in VPX, i've read other threads on this happening.  I use static images instead of b2s for browsing as i dont like the speaker grills.
Dirty Harry and Demolition man gave me fits, and each had its own odd way to fix it.
On Demolition man you have to uncheck hide backglass in game manager, which i've never had to do for any other back glass.
Every backglass/table combination i've tried works perfectly in VPX, but backglass will not show up in PBX for this, the table runs fine.
