Hi friends, how are you?
I own a DMD Vishay lee-128g032b and am using pindmd2.
It happens that, I'm not able to run it in future pinball and pinball fx2.
In the future pinball I followed the jason tutorial.
http://www.gopinball.com/forum/viewtopic.php?nomobile=1&f=55&t=2919
I downloaded the file intercept.zip and put all the folders of this file in the BAM folder (where is my future pinball executable).
I selected a table for the future pinball .exe and clicked on Translite, I clicked the right button on the DMD, unlocked it and dragged it out of Virtual Screen (HUD).
After dragging it (HUDDMD), I modified it to 128x16 and renamed the file to "Mydmd".
The other two files (HUDDMD and DISPDMD) retained the names "Mydmd2" and "leddmd".
I clicked on editor 5 and then clicked on "Play Table" and the dmd is the black screen (not the signal).
I also tried to move the modified HUDMD file to the Virtual Screen (HUD) it appears in the playfield but does not give a signal to realdmd.
I also made the option to rename the DISPDMD as "Mydmd" and modify it to 128x16 leaving the other files in 128x36 but it did not work anyway.
FX2
I managed to do the procedure for installing the freezy program, I even got to test the dmd for it. But when I start the pinball fx2 the dmd does not appear for me. The width configuration 1040 and height 272 was observed. But the dmd still does not appear. What could be happening?
I use windows 10. Can anyone guide me what it can be? I have been trying for days and for long hours but I am not having any evolution and I am very anxious to see it working with the emulators.
Thank you very much and all help is welcome. I wish everyone a great day. Thank you!
The fpintercept library only supports DMD size 128x32
Make sure the driver for your DMD controller is up to date. Run all pinball applications as administrator and make sure all dll files are unblocked. Test by running dmdext from a command line and see if the application log is producing any meaningful messages. Try with virtual DMD output to see if if is just an error using the dmdext program. If you think that you have a bug with dmdext then report it at freezy's github repository.
Thanks for your return!
In the future pinball I tried to change the size in DMD to 128x32 instead of 128x16 but I do not know what I'm doing wrong, because the DMD screen in the future pinball remains black.
FX2
I forwarded the cmd file that looks like PINDMDv2 is running, but the dmd of the FX2 game does not appear.
The procedures you reported appear to be being observed. I think it would be some detail that I can not see. I've lost all my hair. Could you help me ?? Please someone help me !!!!
C:\Users\Thiago>dmdext test
 [1] 2017/04/04 22:50:56.312  INFO | Launching console tool.
 [1] 2017/04/04 22:50:56.344 DEBUG | PinDMDv1 device not found.
 [1] 2017/04/04 22:50:56.375  INFO | Found PinDMDv2 device.
 [1] 2017/04/04 22:50:56.375 DEBUG |    Manufacturer: pinDMD
 [1] 2017/04/04 22:50:56.375 DEBUG |    Product:      pinDMD V2
 [1] 2017/04/04 22:50:56.375 DEBUG |    Serial:       00000000050C
 [1] 2017/04/04 22:50:56.375 DEBUG |    Language ID:  1035
 [1] 2017/04/04 22:50:56.391 DEBUG | Checking port COM1 for PinDMDv3...
 [1] 2017/04/04 22:50:56.484 DEBUG | Error: Parâmetro incorreto.
 [1] 2017/04/04 22:50:56.484 DEBUG | PinDMDv3 device not found.
 [1] 2017/04/04 22:50:56.500 DEBUG | Device found but it's not a PIN2DMD device (pinDMD V2).
 [1] 2017/04/04 22:50:56.656  INFO | Added PinDMDv2 renderer.
 [1] 2017/04/04 22:50:56.719  INFO | Added VirtualDMD renderer.
 [1] 2017/04/04 22:50:56.734 DEBUG | Resizing virtual DMD to 128x32
 [1] 2017/04/04 22:50:56.734  INFO | Setting up Render Graph for 2 destination(s)
 [1] 2017/04/04 22:50:56.750  INFO | Connecting Image Source to PinDMD v2 (Bitmap => Gray4)
 [1] 2017/04/04 22:50:56.781  INFO | Connecting Image Source to Dmd (Bitmap => Bitmap)
 [1] 2017/04/04 22:50:56.797  INFO | Press CTRL+C to close.
 [5] 2017/04/04 23:03:19.463  INFO | Source for 2 renderer(s) stopped.
 [5] 2017/04/04 23:03:19.463 DEBUG | Disposing render graph.
C:\Users\Thiago>dmdext mirror --source=pinballfx2 --no-virtual
 [1] 2017/04/04 22:52:24.852  INFO | Launching console tool.
 [1] 2017/04/04 22:52:24.886 DEBUG | PinDMDv1 device not found.
 [1] 2017/04/04 22:52:24.918  INFO | Found PinDMDv2 device.
 [1] 2017/04/04 22:52:24.919 DEBUG |    Manufacturer: pinDMD
 [1] 2017/04/04 22:52:24.919 DEBUG |    Product:      pinDMD V2
 [1] 2017/04/04 22:52:24.919 DEBUG |    Serial:       00000000050C
 [1] 2017/04/04 22:52:24.919 DEBUG |    Language ID:  1035
 [1] 2017/04/04 22:52:24.919 DEBUG | Checking port COM1 for PinDMDv3...
 [1] 2017/04/04 22:52:25.003 DEBUG | Error: Parâmetro incorreto.
 [1] 2017/04/04 22:52:25.003 DEBUG | PinDMDv3 device not found.
 [1] 2017/04/04 22:52:25.020 DEBUG | Device found but it's not a PIN2DMD device (pinDMD V2).
 [1] 2017/04/04 22:52:25.144  INFO | Added PinDMDv2 renderer.
 [1] 2017/04/04 22:52:25.144 DEBUG | VirtualDMD disabled.
 [1] 2017/04/04 22:52:25.167  INFO | Setting up Render Graph for 1 destination(s)
 [1] 2017/04/04 22:52:25.173  INFO | Press CTRL+C to close.
