RustyCardores Posted March 24, 2017 Share Posted March 24, 2017 I have a working AHK.exe (see spoiler) that I use to launch Kodi and 2 x irfanview slide shows onto separate screens. This works great when launched directly, but I would like to be able to get PBX to launch it for me. If I create an "other" system PBX and try and execute this file though, I can't seem to come up with working config. The best I've achieved in PBX launching the first line slideshow and then dropping back to the menu. Any pointers to a possible "starting point" would be appreciated. Cheers Spoiler run C:\PinballXX\Media\Kodi\IrfanviewTopper_PBX.exe /monitor=4 run C:\PinballXX\Media\Kodi\IrfanviewTableSLideshow.exe /monitor=1 sleep, 2000 run C:\Games\Kodi\Kodi.exe /monitor=3 Link to comment Share on other sites More sharing options...
Carny_Priest Posted March 24, 2017 Share Posted March 24, 2017 Try changing properties of the compiled exe to run as administrator? Do you have PinballX set to run as administrator? Every exe for your cab installation should be set to run as administrator even if your user account is administrator Link to comment Share on other sites More sharing options...
RustyCardores Posted March 24, 2017 Author Share Posted March 24, 2017 Try changing properties of the compiled exe to run as administrator? Do you have PinballX set to run as administrator? Every exe for your cab installation should be set to run as administrator even if your user account is administrator Yep they were all run as admin. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
RustyCardores Posted March 24, 2017 Author Share Posted March 24, 2017 I can make this partially work, if I use Launch After for Kodi.exe (starting last it gets focus) and if I put just a singular slide show exe in the system executable. The result is that I have Kodi operational on my backglass screen and a slide show operation on the playfield. This of course doesn't put the second slideshow up on the topper screen and it is that that I'm trying to achieve. So even when starting Kodi separately, PBX doesn't like the single executable script starting two slideshow.exe's (all Run as Admin) ini & xml files in spoilers... Spoiler [Display] Monitor=0 rotate=270 Windowed=False WindowWidth=1080 WindowHeight=1920 WindowX=0 WindowY=0 PlayFieldBrightness=190 WheelTextColor=ffffffff WheelTextOutlineColor=ff000000 InfoTextColor=ffffffff InfoTextOutlineColor=ff000000 FilterTextColor=ffffffff FilterTextOutlineColor=ff000000 MenuColor=ffc5c5c5 WheelAutoCrop=False ShowExitImage=False [BackGlass] monitor=2 x=0 y=0 width=1360 height=768 UseB2S=False AutoPositionB2S=False [DMD] Enabled=True monitor=3 x=0 y=0 width=1920 height=1080 UsePinMAME=False AutoPositionPinMAME=False [FileSystem] EnableFileMatching=False [Interface] DesktopModeEnabled=False EnableAdditionalDetail=False ShowSystem=False ShowRatings=False EnableDefaultFilters=False OneClickLaunch=False [Audio] StreamVolume=60 SampleVolume=60 PlaySoundInVideos=False [Startup] playsound=True playvideo=False StartWithWindows=Yes [KeyCodes] quit=69 left=67 right=90 select=71 rotate=82 pageleft=33 pageright=34 exitemulator=162 ingame=80 screenshot=75 screenshotbackglass=85 instructions=73 volumedown=109 volumeup=107 credit=53 plunger=13 [Text] Line1=Flippers Scroll - Bottom Right Flipper Selects Line2=Red Button Adds Coin - Green Button Starts Featuring= Tables= All=Back to All PlayGame=Play ExitGame=Exit Exit=EXIT Pinball Shutdown=SHUT DOWN ReturnToGame=Resume Return=Back [FuturePinball] Enabled=False WorkingPath=C:\Games\Future Pinball TablePath=C:\Games\Future Pinball\Tables Executable=Future Pinball.exe Parameters=/open "[TABLEPATH]\[TABLEFILE]" /play /exit /arcaderender LaunchBeforeEnabled=false LaunchBeforeWorkingPath= LaunchBeforeExecutable= LaunchBeforeHideWindow=False LaunchBeforeWaitForExit=True LaunchAfterEnabled=False LaunchAfterWorkingPath= LaunchAfterExecutable= LaunchAfterHideWindow=False LaunchAfterWaitForExit=True MouseClickFocus=True FPRAMPath=C:\Games\Future Pinball\fpRAM [VisualPinball] Enabled=True WorkingPath=C:\Games\VPX TablePath=C:\Games\VPX\Tables Executable=VPinball992.exe Parameters=/play -"[TABLEPATH]\[TABLEFILE]" LaunchBeforeEnabled=false LaunchBeforeWorkingPath= LaunchBeforeExecutable= LaunchBeforeHideWindow=False LaunchBeforeWaitForExit=False LaunchAfterEnabled=False LaunchAfterWorkingPath= LaunchAfterExecutable= LaunchAfterHideWindow=False LaunchAfterWaitForExit=False [ExitScreen] Enabled=True EnableExit=True EnableShutdown=True [StartupProgram] Enabled=False WorkingPath= Executable= Paramaters= HideWindow=False WaitForExit=false [ExitProgram] Enabled=false WorkingPath= Executable= Paramaters= HideWindow=False WaitForExit= [AttractMode] Enabled=True Timer=1 ShowFor=10 MuteAudio=False [System_1] Name=MAME GAMES Enabled=True WorkingPath=C:\Games\MAME 2 TablePath=C:\Games\MAME 2\roms Executable=mameuifx32.exe Parameters=[TABLEFILE] SystemType=0 LaunchBeforeWorkingPath= LaunchBeforeExecutable= LaunchAfterWorkingPath= LaunchAfterExecutable= [AutoExit] Enabled=False Minutes=10 [Login] Enabled=False [PinballFX2] Enabled=True WorkingPath=C:\Program Files (x86)\Steam Executable=Steam.exe Parameters=-applaunch 226980 Process=Pinball FX2.exe WaitFor=15 LaunchAfterEnabled=True LaunchAfterWorkingPath=C:\PinballXX\Media\Pinball FX2 LaunchAfterExecutable=killFX2.bat LaunchAfterWaitForExit=False LaunchAfterHideWindow=False LaunchBeforeEnabled=True LaunchBeforeWorkingPath=C:\Program Files (x86)\Steam\steamapps\common\Pinball FX2 LaunchBeforeExecutable=BorderlessDMD.ahk LaunchBeforeWaitForExit=False LaunchBeforeHideWindow=False [Internal] lastwheelcachematchsize=0 lastselected=** JukeboxKodiSystem_3 filter_year= filter_company= filter_custom=Jukebox filtername=Jukebox [System_2] Name=PhysMOD5 WorkingPath=C:\Games\VPX TablePath=C:\Games\VPX\Tables Executable=VPinball99_PhysMod5.exe Parameters=/play -"[TABLEPATH]\[TABLEFILE]" Enabled=True SystemType=1 LaunchBeforeWorkingPath= LaunchBeforeExecutable= LaunchAfterWorkingPath= LaunchAfterExecutable= [SetupWizard] EmuPath1=C:\Emulators AssetPath1=C:\Assets RomPath1=C:\Roms DefaultPathPrompt=True DownloadDatabasePrompt=True DownloadEmulatorPrompt=True WizardMode=1 CustomArray= SearchArray= SavePosition=False SectionIndex=16 SearchText= EmulatorIndex=0 EmulatorGroupIndex=0 DaphneIndex=0 HTMLAppsIndex=0 ExternalAppsIndex=0 RadioStationsIndex=0 NewsFeedsIndex=0 MappedDrivesIndex=0 SystemIndex=2 ShowPanel=True FontSize=1 WindowState=0 WindowSize=951,762 WindowLocation=159,25 [GameListManager] onlinemode=false [Plugin_1] Enabled=False Name=PlugInLED.dll [Plugin_2] Enabled=False Name=PlugInSpeech.dll [Plugin_3] Enabled=False Name=QuickLaunch (PinballX Edition).dll [Plugin_4] Enabled=False Name=ShineOn.dll [Plugin_5] Enabled=False Name=Xpadder Plugin.dll [System_3] Name=Kodi Enabled=True WorkingPath=C:\PinballXX\Media\Kodi TablePath=C:\Games\Kodi\Tables Executable=IrfanviewTableSLideshow.exe Parameters= LaunchBeforeEnabled=True LaunchBeforeWorkingPath=C:\Games\Kodi LaunchBeforeExecutable=Kodi.exe LaunchAfterEnabled=True LaunchAfterWorkingPath=C:\PinballXX\Media\Kodi LaunchAfterExecutable=killirfanview.bat LaunchBeforeWaitForExit=False LaunchBeforeHideWindow=False LaunchAfterWaitForExit=False LaunchAfterHideWindow=False SystemType=0 WaitForProcess= [System_4] Name=BAM Future Pinball Enabled=False SystemType=2 WorkingPath=C:\Games\Future Pinball\BAM TablePath=C:\Games\Future Pinball\Tables Executable=FPLoader.exe LaunchBeforeWorkingPath= LaunchBeforeExecutable= LaunchAfterWorkingPath= LaunchAfterExecutable= Parameters=/STAYINRAM /open "[TABLEPATH]\[TABLEFILE]" /play /exit [System_6] Name=VPX 10.1 Enabled=True SystemType=1 WorkingPath=C:\Games\VPX TablePath=C:\Games\VPX\Tables Executable=VPinballX101official.exe Parameters=/play -"[TABLEPATH]\[TABLEFILE]" LaunchBeforeWorkingPath= LaunchBeforeExecutable= LaunchAfterWorkingPath= LaunchAfterExecutable= [System_5] Name=SLAMT1LT Enabled=False SystemType=2 WorkingPath=C:\Games\Future Pinball\BAM TablePath=C:\Games\Future Pinball\Tables Executable=FPLoader.exe Parameters=/STAYINRAM /open "[TABLEPATH]\[TABLEFILE]" /play /exit LaunchBeforeWorkingPath= LaunchBeforeExecutable= LaunchAfterWorkingPath= LaunchAfterExecutable= [System_7] Name=10.2 Enabled=True SystemType=1 WorkingPath=C:\Games\VPX TablePath=C:\Games\VPX\Tables\10_2 Executable=VisualPinball-10.2-OFFICIAL.exe Parameters=/play -"[TABLEPATH]\[TABLEFILE]" LaunchBeforeEnabled=False LaunchBeforeWorkingPath= LaunchBeforeExecutable= LaunchAfterWorkingPath= LaunchAfterExecutable= [RealDMD] EnableColor=False [System_8] Name= WorkingPath= TablePath= Executable= Parameters= Spoiler <menu> <game name="Kodi"> <description>** Jukebox</description> <rom></rom> <manufacturer>kodi</manufacturer> <year>2013</year> <type>SS</type> <hidedmd>False</hidedmd> <hidebackglass>False</hidebackglass> <enabled>True</enabled> <rating>0</rating> </game> </menu> Link to comment Share on other sites More sharing options...
RustyCardores Posted March 25, 2017 Author Share Posted March 25, 2017 OK I'm running with the "partially working" system as mentioned above, as I have simply exported my 2nd slideshow as a movie file and PBX feeds the movie from the /DMD Videos folder. A very simple solution and I'm kicking myself for not doing it this way to begin with, as I have always been using the /DMD Images folder to feed the static topper images there anyway. Talk about ignoring the obvious! :-/ Der!! Link to comment Share on other sites More sharing options...
Carny_Priest Posted March 25, 2017 Share Posted March 25, 2017 Does that mean that you are good to go now? I don't run a slideshow, but if I did I would use the script itself to launch the irfanview executables and kodi. I would use PinballX ust to launch only the script. Link to comment Share on other sites More sharing options...
RustyCardores Posted March 25, 2017 Author Share Posted March 25, 2017 43 minutes ago, Carny_Priest said: Does that mean that you are good to go now? I don't run a slideshow, but if I did I would use the script itself to launch the irfanview executables and kodi. I would use PinballX ust to launch only the script. Yep, I'm good now. It does what I set out to do.... just in a different way Having PinballX launch the just the script was my plan.... and it worked for launching Kodi and one slideshow, but as soon as the second slideshow was added to the script (now a total of 3 exe) it would stuff up. A timing issue perhaps? I tried all manner of delays, but could never find a working setup. Link to comment Share on other sites More sharing options...
Carny_Priest Posted March 25, 2017 Share Posted March 25, 2017 Maybe. I don't know much about irfanview. Good enough solution as long as you don't feel like you want to change up your slideshow very much. You'd have to create a video every time, but it's not like that is that hard or time consuming to do. Link to comment Share on other sites More sharing options...
RustyCardores Posted March 25, 2017 Author Share Posted March 25, 2017 True, but thankfully this is a slide show that will never need to change, as it's just to make the neon lights of the jukebox sign light in order and then flash a few times (and then loop) Link to comment Share on other sites More sharing options...
Carny_Priest Posted March 25, 2017 Share Posted March 25, 2017 Nice job. I see you've released the video as part of your topper collection at vpinball. Are the rest of the graphics that you use for your kodi skin available somewhere? Link to comment Share on other sites More sharing options...
RustyCardores Posted March 25, 2017 Author Share Posted March 25, 2017 Yeah the video toppers are pretty basic, just a flashing light here and there. With a few topper builds starting, I just wanted to show the guys that PBX could put a video up there for a bit of animation. I hope that we have a talented animator or two out there (I'm sure we do) that will come on-board and produce something far more advanced than what I'm capable off. Another hope (while I'm here... wink wink) is that one day PBX might duplicate the "DMD Images / DMD Videos" thing and allow "Topper Images / Topper Videos". At present, the toppers steal the ability to display DMD Images on the DMD screen during PBX menu. Not a big deal, as the DMD comes back to life once VP takes control, but it would be nice to be able to have both. At present, I am using a generic DMD image of my cab's name to show on the DMD screen while in PBX menu. I'm doing this by just having it as my Windows desktop image. Re the Kodi graphics: Yeah they are just images I grabbed off the web. I'm happy to pull a copy off the cab if you want them. There is only the one that is associated with Kodi and that's on the backglass obviously. The Jukebox on the playfield in an irfanview slideshow of two images to make the rim lights on the Jukebox glow bright>dull>bright etc (something I need to modify really, as I would like a more obvious change in brightness... I might do that today) I also have a stand alone version of the Jukebox setup that is launched outside of the PBX. It looks the same on the topper and backbox, but the playfield jukebox is replaced by 'Plane9' full screen visualisations. EDIT: I just googled and the image of the glow valves comes up on the first page of results. Heaps of similar images to select from... https://www.google.com.au/search?q=glow+valves+amplifier&espv=2&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwiulMbJx_LSAhWJlJQKHb0fDzMQsAQIHw&biw=1831&bih=1035 Link to comment Share on other sites More sharing options...
Carny_Priest Posted March 25, 2017 Share Posted March 25, 2017 Thanks for the link. Link to comment Share on other sites More sharing options...
