Hi everybody,
I'm trying to get DOF R3 and PinballX to work together, but I'm not getting very far. On my Windows 10 installation, I unblocked all .dll's, and made all .exe run as Administrator. The DOF plugin is correctly set up (it says "found" and "OK").
I enabled logging for the plugin, and it logs the following:
17.03.05 03:46:47.373 Plugin config loaded
17.03.05 03:46:47.373 Initializing plugin
17.03.05 03:46:47.373 Loading PBX config data
17.03.05 03:46:47.388 PBX config data loaded
17.03.05 03:46:47.388 Initializing DOF
17.03.05 03:46:47.905 DOF initialized
17.03.05 03:46:47.905 Loading Table/Romname mappings
17.03.05 03:46:47.924 Table mapping filename: C:\DirectOutput\config\tablemappings.xml
17.03.05 03:46:48.027 PinballX.Table2RomMapping.TableNameMappings TableMappings loaded
17.03.05 03:46:48.028 No romnames are configured in DOF.
17.03.05 03:46:48.028 Table/RomName mapping loaded
17.03.05 03:46:48.028 Sending initial PBX state to DOF
17.03.05 03:46:48.028 Init complete
17.03.05 03:46:51.283 Action: PBXGameSelect
17.03.05 03:46:51.293 Best match for SURFER is SURFER (surfer). Match Value: 1
17.03.05 03:46:51.298 Game selected Surfer (No update sent)
17.03.05 03:46:54.197 Event_Input
17.03.05 03:46:54.466 Action: PBXGameSelect
17.03.05 03:46:54.472 Best match for SURE SHOT is SURESHOT (sureshot). Match Value: 0,842105263157895
17.03.05 03:46:54.478 Game selected Sure Shot (No update sent)
17.03.05 03:46:55.266 Event_Input
17.03.05 03:46:55.536 Action: PBXGameSelect
17.03.05 03:46:55.544 Best match for SUPERMAN is SUPERMAN (superman). Match Value: 1
17.03.05 03:46:55.552 Game selected Superman (No update sent)
17.03.05 03:47:00.946 Event_Input
17.03.05 03:47:03.913 Event_Input
17.03.05 03:47:03.916 Action: PBXMenuUp
17.03.05 03:47:04.329 Event_Input
17.03.05 03:47:04.339 Action: PBXMenuUp
17.03.05 03:47:05.479 Event_Input
17.03.05 03:47:05.483 Action: PBXMenuSelect
17.03.05 03:47:05.652 Exiting PBX
I'm kind of worried about the "No romnames are configured in DOF.". Could that be my problem? I've generated the tablemappings.xml with the vpforums DOF tool online, and the same with my directoutputconfig.ini,
I'm lost....
