There are certain games that I need to use the Escape key for, however, I still want the ability to exit out of the game via GameEx. Is there some way to map a different key to exiting ou of the game other than Escape?
Anyone at all?
under the emulator configuration
advanced config. cut and paste this config in your config file.
this config will perform an ALT+F4 once a specific key sequence is pressed simutansly. I use this config on all my emulators I realize ESC is used in other emus as a function. ALT+F4 will close most anything.
# This is an advanced emulator configuration file. It does things such as allow keyboard only emulators to be operated by a gamepad, wait for additional processes to exit and map keys. If this file is used it overrides the MAPKeys setting for the emulator.
[GENERAL]
# Enabled. Use this.
#Make MCE Back button and X-ARCADE Escape and SlikStik Escape to close emulator process
MapBack=True
#Make Escape key close emulator process
MapEscape=False
#When exiting an emulator via the above mappings, you can specify keys in the send keys format to send instead of having GameEx close the process to cleanly exit the emulator. Such as the Q Key or ALT F4 which is %{F4}
KeysToSendOnExit=%{F4}
#Wait for keys to be processed by the emulator
EmuWaitForKeys=False
#Additional processes to wait to exit or close on exit. Dont include the .exe. Leave blank not to use.
Process1=
Process2=
Process3=
Process4=
[JOYMAPPING]
# For mapping a GamePad to keys
# Specify a virtual key code to send when the specific joystick control is pressed. Look at vkcodes.htm for codes.
JoymappingEnabled=FALSE
Left=37
up=38
Right=39
Down=40
Button1=17
Button2=18
Button3=32
Button4=53
Button5=54
Button6=49
Button7=
Button8=
Button9=
Button10=
[GAMEPADEXIT]
#MAP Gamepad controls to exit and make controls exit process
MapGamePadExit=true
#Flag the controls that exit a game by placing True next to each control. To not use the control as part of the combination use a 0
Left=0
Down=0
Right=0
Up=0
Button1=0
Button2=0
Button3=0
Button4=0
Button5=True
Button6=True
Button7=0
Button8=0
Button9=True
Button10=True
Alright, I'll try some of this out. This will be very useful for PS emulators. Thanks.
LATE EDIT:
I use a Logitech RumblePad & the software that comes with it allows me to bind certain gamepad buttons to keys, is there a way to exit back to GameEx via multiple keyboard keys like we can with gamepad keys?
