I am new at at Vpin so please bare with me.  I have Fx2 setup and running perfect with Freezy's awesome DMDext. But I am struggling with setting on Pro Pinball.
I have a two screen setup plus a pinDMDv3.
Issues-
  • For the DMDext I see there was a mention of adding a .bat file but I am not sure which file that is or where to add it.
  • Is it better to use the startup option via steam to add backglass and if so 2 or 3 screen? I assume DMDext needs to pull from something.
  • Is the backglass that is provided the preferred or only option?
  • Any chance that PinballX will add DMD mirroring within the frontend?
Freezy thank you for the product!!
Are you running it from steam?
My cab is 3 screen
in steam under the property's from the app I added m3 q
try adding m2 q
