Does anyone happen to have an OfflineData.m0d file for Free Cam Mod for Pinball Arcade.
It just updated yesterday and messed up a bunch of my cab tables and I didn't know to make an offline data file. If anyone has one I'd be ultra grateful.
It was my understanding that if any file exists with that name in the directory it will be in "offline mode" and not try to phone home.
So you can just copy any file into that directory and re-name it that, or just open notepad and save a blank file named that in the root of that directory.
No the file is actually version specific. I talked with NoEX about it. I made on and it's for 1.57.12 but I really wanted to keep all my stuff on .10
I thought well maybe I'll just dump the contents of the file try again. It won't work at all then.
So yeah I'd need an offlinedata.m0d from someone who made one for 1.57.10. noex told me to ask on the forums, anyways so here i am.
Oh, did not know that.  It's been awhile but I could have sworn the first time I launched it (and my firewall blocked it) it popped up some dialog saying I needed to create XXX named file to make it work offline.
Yeah it does. Then when you make that file it makes a version specific offline file. Unfortunately I didn't make one before it switched so if i make one now it makes an offline version for the wrong version
Oh I guess what I also didn't say is to make that file you go to the icon in the statusbar and double click it and it builds that offline file for you. You don't just create a blank file.
  • 2 months later...
