I just set up my pinballx and the fx2 tables are working fine. My problem is that the visual pinball tables aren't showing up. I've checked the paths over and over and can't figure out why they're not appearing. I've tried the filters for pinballx tables and the only tables shown are the fx2 tables. Anyone have any ideas what's going on? I just downloaded the updated pinballx btw. Thanks
[VisualPinball]
WorkingPath=C:\Visual Pinball
Executable=VPinballX.exe
LaunchBeforeEnabled=false
LaunchBeforeWorkingPath=
LaunchBeforeHideWindow=False
LaunchBeforeWaitForExit=True
LaunchAfterEnabled=False
LaunchAfterWorkingPath=
LaunchAfterHideWindow=False
LaunchAfterWaitForExit=True
AutoConfigure=False
EnableFullScreenExclusiveHack=False
[ExitScreen]
this is how it looks in config.
Did you bring any tables in via game manager? IIRC, I had to add tables manually. FX2 was automatic.
