I had pinball ultra working in my cab using steam with the m3 q setting in launch
Now I see the options for DMD and backglass but the DMD and backglass have disappeared
Any Ideas currently stumped
In order to replace and adjust the Backglass and the DMD we will go to GRAPHICS from this menu of general options of the game to put it in window mode instead of Full Screen since at the beginning they are under the Playfield.
In the graphics options of this main menu you also have to put your vertical resolution (put 1080 you have the desktop as you have it if your resolution is 1920X1080 or 1080X1920).
You can adjust the graphics quality for more modest equipment if necessary.
Once you have everything right, in this menu you will activate FULL SCREEN again.
Para poder recolocar y ajustar el Backglass y el DMD nos iremos a GRAPHICS desde este menú de opciones generales del juego para ponerlo en modo ventana en lugar de Full Screen ya que al principio quedan bajo el Playfield.
En las opciones de gráficos de este menú principal también tienes que poner tu resolución vertical (pon 1080 tengas el escritorio como lo tengas si tu resolución es 1920X1080 o 1080X1920).
Puedes ajustar la calidad de gráficos para equipos más modestos si fuera necesario.
Una vez lo tengas todo bien, en este menú volverás a activar FULL SCREEN.
Thanks for the reply PCTeknic
I have followed your instructions but I only get one windowed screen instead of three
But if I go into setting I do see the options change based on M3 or no M3 settings
Still stumped
J
When you put it in window mode, you can move the window a little and you will see that the backglass is hidden there, so you can drag it to your site and give it the correct size.
Once done, you can return to full screen.
The problem is that it's under the playfield, so you have to do this.
I got finally Solved
Thanks PC Teknic
I was only changing the playfield to windowed You have to do it for the DMD and Backglass as well
