Not Able to Get to Pinball Arcade R-Z Tables
Is anyone else having problems with PBX launching Pinball Arcade tables that are listed in the R-Z alphabetical section?  Every table before the letter R works fine, but when PBX scrolls down it gets to the first row of the R-Z section and then it seems like TPA scrolls back up so that the focus is on the previous section.  Based on how many rows down PBX has to go in the R-Z section it will bounce around for a while before then moving across to select a table.
Do the grid X Y positions in the XML file look correct?
Ever since PBA redid their menu interface to also work as a touch screen for mobile devices, it has been a PITA for all involved.
I think the grid positions are right, at least they follow the same format as the other ones in the other alphabetical groups that work.  So that is a no go on this even working for anyone?  It's not just me?
Integrated support may work for some, but not for everyone. I get the same behavior as you. I'm not real motivated to do a work around. There is nothing that TPA does that VP doesn't do much better.
Some people may not agree with that assessment and they are certainly entitled to their totally wrong opinions.
An alternative for you might be working through the My Tables menu which would be set up as one big grid. Again, didn't work completely without errors for me.
Where there is a will there is a way. If you are very determined you could control the selection very precisely if you code your own AutoHotkey script.
Sent from my iPhone using Tapatalk
Thanks for responding.  I like the VP tables a lot as well.  Just wanted to get TPA working since I bought a few seasons.
There was an application and AHK script by ginsonic from January of 2016 that looks promising, i'll give that a whirl before dusting off the appdev skills to roll my own.
