[RESOLVED] Input controls not working in PinballX (RShift, LShift, Esc)
Hi,
I just want to post a possible solution/cause of input problems with some keys in PinballX. I was encountering the problem that the shift keys were not working within PinballX. I changed the assigned keys for menu navigation but nothing worked. After starting a table (Enter did still work), the shift keys worked as intended in Visual Pinball. Finally the Esc key also did not open the exit dialogue when back in PinballX again.
After checking the ini file and finding all in order, I discovered the solution. One of the function shift sliders on my Flightstick X45 (throttle module) was moved to a different position. After changing the switch position there, PinballX worked as intended again.
Regards
Michael
