Gildahl Posted December 21, 2016 Posted December 21, 2016 I just noticed a little glitch today that may have been there for a while. With my settings, GameEx displays 20 games on a page. When I page down, it actually advances by 21 items, so every page down will fail to display one item between each page down operation. If I page down, then scroll back up by one item, I'll see the missing item. Page Up does the same thing. If I change the font size to show fewer items on a page, it still misses one item for each page down/up operation. I am using custom menus. GameEx.ini
Gildahl Posted December 21, 2016 Author Posted December 21, 2016 Default - Deep Purple ... although the issue is also there in Default - Default.
DazzleHP Posted December 21, 2016 Posted December 21, 2016 Do you use Xpadder/Pinnacle or any other mapping software? Not saying it is the culprit, but if you use one it should be considered
Gildahl Posted December 22, 2016 Author Posted December 22, 2016 No, nothing like that. By your reply, however, I'm assuming you don't see this?
Tom Speirs Posted December 22, 2016 Posted December 22, 2016 I did actually see the issue myself too the other day so it is confirmed. I will look at it.
