I upgraded to VPX 10.2 beta now when I push my exit button on my cab. instead of exiting out to pinballx. I get a small resume menu.
Any Ideas
That should work if you're using the auto configure option.
If not, open the new executable and check the controls.
PinballX should not use the Scape key as Exit since you will have that bug that you comment on.
I have the Q as exit in PinballX.
