I've been having problems with attract mode through several versions now.I'm using the latest v3.51 now,here are some of the problems I've been having lately.
starting with version 3.48,3.50 and 3.51 did it also.The 1st time I start gameex it will not load and I get a full screen sized log file as gameex exits.After the 1st attempt it seems to load normally so its not a huge problem.Here is the log text from the 1st v3.51 startup.
08:32:38.9 4/10/2005: GameEx: Version 3.51: Starting Log
08:32:38.9 4/10/2005: Operating System Platform ID: Win32NT
08:32:38.9 4/10/2005: Operating System Version: 5.1
08:32:38.9 4/10/2005: Running Randomize()
08:32:38.9 4/10/2005: Running Misc startup tasks
08:32:38.9 4/10/2005: Hiding Cursor
08:32:38.9 4/10/2005: Opening Configuration File
08:32:38.9 4/10/2005: Getting Configuration Values
08:32:38.9 4/10/2005: Using Theme: Default - Default
08:32:38.9 4/10/2005: Checking for alternate Image Directory for Theme: Default - Default
08:32:38.9 4/10/2005: Applying Language/Text
08:32:39.0 4/10/2005: SlikStik support enabled
08:32:39.0 4/10/2005: Using DirectInput for keyboard input
08:32:39.0 4/10/2005: Launching HideOS.exe
08:32:39.8 4/10/2005: Hiding Taskbar
08:32:39.9 4/10/2005: Getting Original Screen Size
08:32:39.9 4/10/2005: Loading ICON
08:32:39.9 4/10/2005: Initializing Component
08:32:40.0 4/10/2005: Using General Font: Trebuchet MS
08:32:40.0 4/10/2005: Using Title Font: Trebuchet MS
08:32:40.0 4/10/2005: Initialising DirectDraw
08:32:40.0 4/10/2005: Creating DirectDraw Device
08:32:40.1 4/10/2005: Setting Resolution to 1024x768 32 bit color
08:32:41.0 4/10/2005: Creating DirectDraw Surfaces
08:32:41.0 4/10/2005: Creating Primary Surface - Full Screen Mode
08:32:41.2 4/10/2005: Creating Back Buffer
08:32:41.2 4/10/2005: Loading graphic surfaces
08:32:42.6 4/10/2005: Creating Fonts
08:32:42.6 4/10/2005: Creating Menu Font
08:32:42.8 4/10/2005: Creating Game Font
08:32:42.9 4/10/2005: Creating Menu Font Standard Size
08:32:43.4 4/10/2005: Creating Font Black
08:32:43.5 4/10/2005: Creating Font Black Small
08:32:43.5 4/10/2005: Creating Game Font Faded
08:32:43.7 4/10/2005: Creating Title Font
08:32:44.2 4/10/2005: Initialising Windows Media Player Component
08:32:44.2 4/10/2005: HTML Apps is on, initialising Web Browser Component
08:32:45.2 4/10/2005: MAME Path is: C:\mame
08:32:45.2 4/10/2005: MAME EXE file is: mame.exe
08:32:45.2 4/10/2005: ROM Path is: C:\mame\roms
08:32:45.2 4/10/2005: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
08:32:45.2 4/10/2005: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
08:32:45.3 4/10/2005: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
08:32:45.3 4/10/2005: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
08:32:45.3 4/10/2005: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
08:32:47.7 4/10/2005: Loading Controls.ini map file
08:32:47.7 4/10/2005: Loading Custom Emulators
08:32:47.8 4/10/2005: Snap Path is: C:\mame\snap
08:32:47.8 4/10/2005: AVI Snap Path is: C:\mame\attract
08:32:47.8 4/10/2005: Flyer Path is: C:\mame\flyers
08:32:47.8 4/10/2005: Cabinet Path is: C:\mame\cabinets
08:32:47.8 4/10/2005: Title Path is: C:\mame\titles
08:32:47.8 4/10/2005: Panel Path is: C:\mame\cpanel
08:32:47.9 4/10/2005: Icon Path: Not Found
08:32:47.9 4/10/2005: Marquee Path is: C:\mame\marquees
08:32:47.9 4/10/2005: Attempting to load game list
08:32:48.0 4/10/2005: Loading last used Game List
08:32:48.2 4/10/2005: Initialising Bass Audio Library
08:32:48.4 4/10/2005: Loading music from Windows Media Player
08:32:48.5 4/10/2005: Creating DirectSound Device
08:32:48.5 4/10/2005: Trying: Primary Sound Driver
08:32:48.5 4/10/2005: Loading Sound Files
08:32:48.6 4/10/2005: DirectSound Device Created Successfully
08:32:48.6 4/10/2005: Initialising DirectInput for Gamepad support
08:32:48.6 4/10/2005: Initialising DirectInput for Keyboard support
08:32:48.6 4/10/2005: Playing Startup Video
08:32:48.7 4/10/2005: Initialization OK! Starting GameEx!
08:32:48.7 4/10/2005: Testing Main Loop Once: Processing Frame
08:32:48.7 4/10/2005: Testing Main Loop Once: Getting Tick count
08:32:48.8 4/10/2005: Testing Main Loop Once: Checking for song change
08:32:48.8 4/10/2005: Testing Main Loop Once: Checking Keyboard for Input
08:32:48.8 4/10/2005: Testing Main Loop Once: Front buffer exists?
08:32:48.8 4/10/2005: Testing Main Loop Once: Surfaces need restore?
08:32:48.8 4/10/2005: Testing Main Loop Once: Checking Joystick for input
08:32:48.8 4/10/2005: Testing Main Loop Once: Drawing Background
08:32:49.0 4/10/2005: ERRORS DETECTED: EXITING
other issues are
my attract videos(set to run in small window to the left,not as background image) will play fine but there is a huge delay before the audio starts and once in a while the video disappears to a black box and you have to exit and restart gameex to fix.
attract mode
if I leave the default set to 4,the screen goes completly black with no sound
if I set to 0 to disable attract mode,after a while gameex minimizes itself to the taskbar.
I like the idea of the attract mode but haven't had a lot of luck with it,I'd at least like to disable it and keep the gameex menu active.
other issues are
attract mode
I think this may be partly due to your setup. If the timer is set to 0 it is deffinitly not attract mode that is minimizing gameex. It will deffinitly be disabled. Its either some other bug with GameEx or another application window taking focus away from GameEx. What else do you have running?
Can you confirm whether you are using AVI or MNG videos also. If its AVI, it must be your setup, as theres really nothing that could be a problem with audio in the GameEx code. If their MNG it could be an issue with GameEx however.
On thing that might fix the videos, is setting GameEx not to create the snap/video on a thread. This is under Tweaks/Performance in the configuration app.
Let me know if turning that off improves things.
If anyone else is experiencing the same issues please report.
Thanks,
Tom
there are no other open apps running when it minimizes,its installed on my primary computer for now so its got a few things in the system tray,norton and a few other utilities,maybe a culprit I don't know.I didn't see the minimizing problem before v3.48.I changed that setting in the tweaks tab about the video-thread thing to no,I didn't know what that did so I left it alone at first,we'll see if that changes it's behavior.Also I didn't see the audio problem untill v3.48 either.I'm going to have to get the last few components for the computer thats going into my cab so I can run it on a system without any extra fluff on it and see if it's ok then.And videos I'm using are AVI's,and again they played ok on v3.47.
