Hi
I use fs-uae to two systems: Commdore CDTV and Amiga CD32.  but with my x-arcade joystick I don't know how to emulate this
I use standard command line but where I can add the parameters of x-arcade ?
fs-uae.exe --amiga-model=CD32 --joystick-port-0-mode="cd32 gamepad" --fullscreen=1 --keep_aspect = 1 --cdrom-drive-0="[ROMPATH]\[ROMFILE]"
fs-uae.exe --fullscreen=1 --amiga-model=CDTV --joystick-port-0-mode=joystick --keep_aspect = 1 --cdrom-drive-0="[ROMPATH]\[ROMFILE]"
thanks
There is a pre-programmed option within gameex. I have not used it, but maybe it will fit your needs. From looking it over, it sounds like it makes the x-arcade look like a joystick. I would assume as long as the emulator allows configuration to a gamepad or stick, this will work.
https://support.xgaming.com/support/solutions/articles/12000003063-gameex-frontend-and-the-x-arcade
I used to have an old x-arcade single stick, butnot long ago I yanked the guts out and put in an ipac. When I used it as an x-arcade, I would set it to programmable mode and set the buttons/stick to whatever key I wanted.
Either way, no change to the command line of the emulator would be needed.
