when I'm running pinball x with visual pinball and setup exit emulator to a certain button it doesn't do anything. When I setup a button in Visual Pinball then it just goes to an exit screen and then i need to use my mouse and i want to just exit back to pinball x?????
Help!
Found out from another thread that i need to set the pinball X program as administrator. to do this you right click on the .exe file and then properties and then check the box "run as administrator" at the bottom of the screen. Good to go!!!
