Hello Community,
I have two installations, one with a GTX750 and the other with a GTX760. Both are running correctly with VP921 (Others), VP991 (VP), VPX (Others) and FP (FP). The installation with the GTX760 shows in most of the loading of a FP- table not the loading screen but instead a full white screen (playfield monitor, only). When the loading process is ended the game plays correctly. Leaving the game and return to the PinballX selection menue is without any remarkable.
In another thread that has been closed already I found the hint that the reason is in the parameter line for starting the game (in both cases I am using BAM & its FPloader.exe):
GTX750:
/STAYINRAM/open "[TABLEPATH]\[TABLEFILE]" /play /exit                 works fine
GTX760:
/STAYINRAM/open "[TABLEPATH]\[TABLEFILE]" /play /exit                 crashes
/STAYINRAM /open "[TABLEPATH]\[TABLEFILE]" /play /exit                showns temporarily white screen, but works
note the difference is in the "[SPACE]" behind STAYINRAM
Thank you for any suggestion, Christian.
21 hours ago, Carny_Priest said:
There should be a space between /STAYINRAM and /open
yes, this setting causes the trouble (see chart in my initial message) ... anyway, thank you for your intention to help,
greetings, Christian.
19 hours ago, Outhere said:
This what I use
/open "[TABLEPATH]\[TABLEFILE]" /play /exit /arcaderender /STAYINRAM
Hi Outhere,
I tried ... it worked at first trial. I'll observe the situation (the original parameter setting worked time and again correctly), with more experience I'll give here a feedback.
Thank you very much, greetings, Christian.
