Hey all,
i have a strange poblem which you might already know and might have a quick solution for me ;) (at least i hope so :unsure:)
the thing is .. on very few tables (e.g circus voltaire vpx and last action hero vpx) i get a .net framework
error while loading them from pinballx. when i start the problem tables from the game manager all is fine.
when i start the problem tables from pinballx_lite all is fine, also. when i disable b2s in the scripts of these
tables the start works fine within the regular pinballx :blink:.
attached are the error messages i see when starting the tables (in this case circus voltaire).
i dont see any error within the pinball x log. setting up these tables in a custom pinballx list didnt help.
tried out different tables for the same pinball and various backglasss but non worked ...
anyone ever stumbled across anything similar ?
cheers
kev
okay ... not sure exactly what the problem is, but after i switched back to my other harddrive with a win7 setup all is fine here. seems to be some windows 10 related stuff which causes the trouble. since i copied the pinballx and visual pinball folders from win10 to the win7 drive i can be sure, that it's not related to some strange setting issue within vpx or pbx ... win10 seems to be a bit picky on something :blink::wacko:
You should try rerunning the Visual Pinball installation program and VPinMAME setup rather than just only copying your setups from another drive. Re-install PinballX as well.
Sent from my iPad using Tapatalk
I too am having this issue,  reinstalled pinballx, vp, windows 10.   this error only appears when launching from pinballx.  vp launchies it just fine.
  • 2 months later...
Did anybody resolve this issue ? I am experiencing the same error with the star trek le table. One when running it from pinballx. No problems using just vpx.
Thanks Carny_Priest. I will check these out. So hard to keep Up these days :) Keep it up. Will let you know what the results are
