PBX crashing in Win 10 after running for a bit? ...maybe this is your problem...
I recently updated both Pinball X to the newest version and I also updated Win 10 the anniversary update.
After this I was having PBX crash after running for 1 to 10 mins.  All of my drivers, LAV codecs, and everything I could think of, I manually got up to date after the Win 10 update (which did a clean NVidia driver install...grrrr! )
I even made sure that I converted EVERY video I had to the same 30 fps mp4 format to be sure that wasn't an issue (using Tom's excellent Convert-it). Long over due...but it wasn't the problem.
Disabled every plug-in, was ready to do a fresh PBX install.... but I checked on last thing....
Turns out it was MSI Afterburner that was causing only PBX to crash, and nothing else. Normally you don't need this for a pinball cabinet, but I was using it for helping roar with his VPX issues. I don't know if a newer version of MSI Afterburner would work fine with the WIN 10 update... but after uninstalling it, my PBX crashing issues are gone!
Hope this helps anyone else with this issue!
