Hi,
I'm using Quicklaunch with PinballX to start two apps when Pinball FX2 is started. The apps are DOFLinx and DMDExt.
I can get DOFLinx to start and terminate just fine with Quicklaunch but DMDExt is a different story. I get the following error: "Cannot Start Process" and then another message box with a few details about arguments etc.
If I click the 'okay' button in the message boxes, DMDExt will actually start. I have the same issue when quitting out of a Pinball FX2 table.
I'm using a .bat file to call DMDExt. I was trying to work around the problem as I get the same error if I call DMDExt.exe directly.
If I click away the error messages, it all runs perfectly. But how do I get rid of the errors please?
Any ideas? :blink:
This is my Settings.xml file:
Quote
<?xml version="1.0" encoding="utf-8" standalone="yes"?>
<quicklaunch_pbx>
  <settings>
    <xml_ver>1.1</xml_ver>
    <created>24 September 2016 12:17:56</created>
    <debug>False</debug>
  </settings>
  <system name="Pinball FX2">
    <switch name="DOFLinx">
      <exepath>C:\Program Files (x86)\Visual Pinball\Tables\plugins\directoutput\DOFLinx.exe</exepath>
      <command>PACLED64=1
      </command>
      <type>2</type>
    </switch>
  </system>
    <switch name="">
      <exepath>C:\Pinballx\dmdext.bat</exepath>
      <command>
      </command>
      <type>2</type>
    </switch>
  </system>
    <switch name="DOFLinxMsg">
      <exepath>C:\Program Files (x86)\Visual Pinball\Tables\plugins\directoutput\DOFLinxMsg.exe</exepath>
      <command>QUIT
      </command>
      <type>1</type>
    </switch>
  </system>
    <switch name="dmdext">
      <exepath>C:\Pinballx\dmdext_quit.bat</exepath>
      <command>
      </command>
      <type>1</type>
    </switch>
  </system>
</quicklaunch_pbx>
I find I have to both run PFX2 as an "other system"... AND I also have to run an exe file (converted from an AHK) that will run dmdext, then delay the launching of PFX2, so dmdext will work. I also have DOFLinx running in quicklauch.
Here is what I use in my AHK file:
Run, "c:\zip\dmdext\dmdext.exe" mirror --source=pinballfx2 -q -d virtual --virtual-stay-on-top --virtual-hide-grip --virtual-position 2234 1528 1280,,Hide
Process, wait, dmdext.exe
Sleep, 5000
I have the above code complied into a "dmdext_delay.exe" in my normal "Launch before" for PFX2. Just make sure to try PFX2 as an "other system". Have the "dmdext_delay.exe" run as admin.
10 hours ago, Carny_Priest said:
What are the contents of the bat file?
dmdext.bat
Quote
C:\PinballX\dmdext.exe mirror --source=pinballfx2 --no-virtual --quit-when-done
dmdext_quit.bat
Quote
C:\PinballX\dmdext.exe -q
@TerryRed
Cheers mate. I'll have to give that a try. A problem I see with this is that I already use the 'Launch Before' parameters for Pinball FX2 for DOFLinx stuff (DOFLinxMsg). How do you get around that issue?
I have DOFLinxMsg running in my Quicklaunch for "Launch Before", and I have the dmdext_delay.exe running with the normal "Launch Before".
Quicklaunch has a bug that doesn't save everything that you enter using the gui (at least for me ), so I just enter everything in the config file manually, and it all works great.
Okay, makes sense. So you have DOFLinx.exe called at startup of your PC then?
Yeah, I enter all that stuff manually too ;)
I actually have Pinball X load DOFLinx when PBX first loads, and then I have PBX msg DOFLinx to "quit" when PBX exits.
I just find it easier to have PBX start up everything I need in a BAT file instead of having to deal with Windows startup issues with Win 10. Just always make sure all programs run as admin, and make sure all BAT files have a shorcut to run as admin as well.
I have DOFLinx always running , and then I MSG a SUP config file for each system that I use for DOFLinx, when I launch a table. This allows for a different setup for each system.
My controller emulates a joystick, and I'm not able to map my Exit button to anything that quits the program using x360ce. I have to map it to a key with a joytokey type program that itself kills all processes so that FX2 quits cleanly. PinballX's integrated support gives me trouble too. I run this ahk script in Other Systems using Custom. Should be able to run the DOF stuff with it.
Spoiler
#NoEnv
#SingleInstance force
#WinActivateForce
SetTitleMatchMode, 3
DetectHiddenWindows, On
; User inputs
antimicro_Path=c:\antimicro
dmdext_Path=c:\dmd-extensions
RegRead, SteamDirPath, HKCU, Software\Valve\Steam, SteamPath
Table=%1%     ;Variable from PinballX
Run, %antimicro_Path%\antimicro --no-tray --hidden --profile "%antimicro_Path%\profiles\VP.joystick.amgp"
; Mirror and flip DMD for P2k
Run, %dmdext_Path%\dmdext mirror --source=pinballfx2 --destination=virtual --virtual-hide-grip --virtual-position 5760 400 1600 --flip-y -q,, Hide
Sleep, 5000
Run, "%SteamDirPath%\Steam.exe" -applaunch 226980 "%Table%"
WinWait, ahk_class PxWindowClass
Process, WaitClose, Pinball FX2.exe
Run, taskkill /im antimicro.exe /f,, Hide
ExitApp
#IfWinActive ahk_class PxWindowClass
; Exit Table
    e::
        Gosub killApp
    Return
#IfWinActive
killApp:
    Send {Esc}
;    Sleep, 500
;    Loop, 4
;            Send {Down}
;            Sleep, 20
;    Send {Enter}
    Sleep, 20
    Send !{f4}
    Process, Close, Pinball FX2.exe
    If ErrorLevel
        Process, Close, %ErrorLevel%
    WinKill, Error
    If ErrorLevel
    WinKill, Error
    WinKill, ahk_class PxWindowClass
    Run, taskkill /F /IM Pinball FX2.exe /T,, Hide
Return
  • 4 months later...
I've got the same errors when using dmdext via quicklauncher. May I ask how you sorted things out? I also use launch before in PinballX to parse the tablename via doflinxmsg.
Thanks for the help!
