I have determined that for some reason B2S Backglass server causes severe lag in some the the older VP 9 tables such as Funhouse and Jokerz!.
I have tried for weeks to resolve it but I was unable. I am going under the impression it is because I am running all the screens off 1 EVEGA GTX 970 with i7 and 6 gigs of triple channel memory. However, B2S runs fine with VPX.
Because I am unable to run B2S with VP9 I want to disable in it Pinball X. I have tried turning it off in the set up, hiding it on the game manager, and writing it out of the script for the table.
It still will not go away. I notice when the table errors out (References to objects in the script it does not understand etc) it opens the script window which still shows B2S.Server is in use even though when I load the same exact table without Pinball X it shows the VPinMAME controller instead.
Does Pinball X keep it's own Script for each table somewhere else? How do I get the Back Glass to turn off and stay off with Pinball X?
Thank You
UPDATE: I found the problem. I had the table in the wrong list in game manager. So VPX was trying to load a VP9 table.
