Audio for pinballx continues playing after table is loaded
I'm not sure if this is being caused because pinballx thinks the table didn't load so it regains focus or something but after I load tables the pinballx audio will continue to play.  Also several tables I load pinballx will say "now loading" but then go back to the pinballx main screen and then the table loads.   What am I doing wrong?
Here is what happens on any Future Pinball table
1. Press "Play Game"
2. Says "Now Loading"
3. Returns to Pinball X menu
4. Screen flickers
5. FP begins to load
6. FP Loads and is on display(ie. the in focus window), but PinballX audio is still playing, my controller isn't controlling the FP table but the Pinball X menu
log:
17:15:30.4  8/29/2016:  PinballX - Version 2.21
17:15:30.4  8/29/2016:  Windows 10 Home 64-bit (15.9GB)
17:15:30.4  8/29/2016:  Loading Settings
17:15:30.5  8/29/2016:  Initialize Component
17:15:30.5  8/29/2016:  Initialize Display
17:15:31.5  8/29/2016:  Loading PlugIns
17:15:32.0  8/29/2016:  Created DirectX BackGlass Window
17:15:32.1  8/29/2016:  Hiding Cursor
17:15:32.1  8/29/2016:  Hiding Taskbar
17:15:32.1  8/29/2016:  CPU:  Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
17:15:32.1  8/29/2016:  GPU 1: NVIDIA GeForce GTX 980 Ti
17:15:32.1  8/29/2016:  Displays: 2
17:15:32.2  8/29/2016:  Load Game List
17:15:32.2  8/29/2016:  Loading Database: Future Pinball
17:15:32.2  8/29/2016:  Loading Database: Visual Pinball
17:15:32.2  8/29/2016:  Loading Database: Visual Pinball 9
17:15:32.2  8/29/2016:  Finding and matching artwork and videos
17:15:32.5  8/29/2016:  Loading Game Statistics and Scores
17:15:33.0  8/29/2016:  Main display running full screen windowed.
17:15:33.0  8/29/2016:  Loading Surfaces
17:15:33.1  8/29/2016:  Finished Loading Surfaces
17:15:33.1  8/29/2016:  Initialize Audio
17:15:33.2  8/29/2016:  Set Keyboard Controls
17:15:33.2  8/29/2016:  Initialize Joystick
17:15:33.3  8/29/2016:  Auto configure Visual Pinball
17:15:33.3  8/29/2016:  1 Joysticks Attached
17:15:33.3  8/29/2016:  Started
17:15:36.3  8/29/2016:  Exiting
17:15:36.3  8/29/2016:  Showing Taskbar
17:15:36.3  8/29/2016:  Unhiding Mouse Cursor
17:15:36.3  8/29/2016:  Disposing Plugins
17:15:36.3  8/29/2016:  Saving Settings
17:15:36.3  8/29/2016:  Bye
ini:
[Display]
Monitor=0
rotate=270
Windowed=False
WindowWidth=480
WindowHeight=720
WindowX=0
WindowY=65
PlayFieldBrightness=230
WheelTextColor=ffffffff
InfoTextColor=ffffffff
InfoTextOutlineColor=ff000000
FilterTextColor=ffffffff
MenuColor=ffffa500
FullScreenWindowed=True
WheelAutoCrop=False
[BackGlass]
monitor=1
x=0
y=0
width=1920
height=1080
AutoPositionB2S=True
UseB2S=True
[DMD]
Enabled=False
monitor=2
x=0
y=0
width=900
height=300
AutoPositionPinMAME=False
[FileSystem]
EnableFileMatching=True
[Interface]
DesktopModeEnabled=False
EnableAdditionalDetail=True
ShowSystem=True
ShowRatings=False
WheelOverlay=3
[Audio]
StreamVolume=90
SampleVolume=90
PlaySoundInVideos=True
[Startup]
playsound=True
playvideo=False
StartWithWindows=No
[KeyCodes]
quit=27
left=160
right=161
select=49
rotate=82
pageleft=37
pageright=39
exitemulator=27
ingame=80
screenshot=83
screenshotbackglass=66
instructions=73
volumedown=109
volumeup=107
credit=53
plunger=13
[JoyCodes]
quit=1
left=200
right=201
select=0
rotate=
pageleft=
pageright=
exitemulator=6
ingame=7
instructions=
[Text]
Line1=Free Play
Line2=Press Start
Featuring=Featuring
Tables=Tables
PlayGame=Play Game
Instructions=Instructions
Information=Information
Flyer=Flyer
Gameplay=Gameplay
Tutorial=Tutorial
ExitGame=Exit Game
ReturnToGame=Return to Game
Return=Return
Exit=Exit
Shutdown=Shutdown
[FuturePinball]
WorkingPath=U:\pinball\FP\program\Future Pinball\BAM
TablePath=U:\pinball\FP\program\Future Pinball\Tables
Executable=FPLoader.exe
LaunchBeforeEnabled=false
LaunchBeforeWorkingPath=
LaunchBeforeHideWindow=False
LaunchBeforeWaitForExit=True
LaunchAfterEnabled=False
LaunchAfterWorkingPath=
LaunchAfterHideWindow=False
LaunchAfterWaitForExit=True
MouseClickFocus=True
[VisualPinball]
WorkingPath=U:\pinball\Visual Pinball
TablePath=U:\pinball\Visual Pinball\Tables
Executable=VPinballX.exe
LaunchBeforeWaitForExit=False
AutoConfigure=True
[ExitScreen]
EnableExit=True
EnableShutdown=True
[StartupProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=true
WaitForExit=false
[ExitProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=False
WaitForExit=
[AttractMode]
Timer=1
ShowFor=15
MuteAudio=False
[System_1]
Name=MAME
Enabled=False
TablePath=C:\
Executable=mamep64.exe
Parameters=[TABLEFILE]
SystemType=0
[AutoExit]
Enabled=False
Minutes=10
[Login]
[PinballFX2]
Enabled=False
Executable=steam.exe
Parameters=-applaunch 226980 [TABLEFILE]
Process=Pinball FX2.exe
Rotate=False
WaitFor=20
[Internal]
lastwheelcachematchsize=626423
lastselected=Jurassic Park (Data East 1993)jurasic-normalFuturePinball
filter_year=
filter_company=
filter_custom=
filtername=Tables
lastwheelcachematchsize2=61057
[PinballArcade]
Parameters=-applaunch 238260
Process=PinballArcade.exe
WaitForSelect=50
[GameListManager]
onlinemode=true
[RealDMD]
EnableColor=True
Color=ffff1414
[SetupWizard]
EmuPath1=C:\Emulators
AssetPath1=C:\Assets
RomPath1=C:\Roms
DefaultPathPrompt=True
DownloadDatabasePrompt=True
DownloadEmulatorPrompt=True
WizardMode=2
CustomArray=Display Settings
SearchArray=
SavePosition=False
SectionIndex=21
SearchText=
EmulatorIndex=0
EmulatorGroupIndex=0
DaphneIndex=0
HTMLAppsIndex=0
ExternalAppsIndex=0
RadioStationsIndex=0
NewsFeedsIndex=0
MappedDrivesIndex=0
SystemIndex=1
ShowPanel=True
FontSize=1
WindowState=0
WindowSize=650,479
WindowLocation=187,1031
[System_2]
Name=Visual Pinball 9
SystemType=1
Executable=VPinball992.exe
