A sinple question you may or may not have an answer to. You have a Slingbox. You have a Set Top Box (or other converter). You have a Router. You have 5 devices (PC's) connected to the ONE router via WiFi and each can access anywhere on the Web thorugh the router separately. You can watch multiple streams on separate channels on any web page feed.. HOWEVER - you can only connect ONE device to your Slingbox at any time.  (even though the signal is there ON the router available to any other devices on your network).
So the question is WHY only one device is limited and devoted solely to the Slingbox to receive the stream?
TIA
