post any questions here and if anyone can answer them that would be great..
first question
what is the best compression codec to use and where do i get it
gerble1000
first question
gerble1000
there are two main codec's DivX and XviD
XviD is Probly the best but can be hard to get workin right as there are so many veriants of it
it isnt realy down to compression its down to the bit rate of the video, i dont think you can actuly change the compression ratio, i have never seen an option to do this. Obviously the higher the bit rate the better quality picture you "should" Have, this will be down to the Quality of the original source
Since we're on the topic.....
I downloaded some of the Video Snaps from EMU, and they're encoded in DIVX. I put them in the right folder and they play in the stand alone player but in Game Ex, when I get to a game that has a Video Snap, Game Ex just minimizes back to the Desktop and all I get is sound from the Video.
Is there some setting to enable Divx in Game Ex, cause other types of AVI's work fine.
I have the divx decoder installed BTW.
This is a very common problem.. you need to uninstall the offical DivX codec and install the ffdshow daily build instead.
Thanks, that did it. I didn't think it was a common thing (just something I did wrong) So I didn't search for it.
Thanks Again
i installed the latest ffdshow xvid
and i cant seem to create avi's through gameex
it starts to work and when i exit it after a few games to check,
it comes up blank
so i go to the folder where it is stored and the file is there but it contains no data (0kb)
im obviously doing something wrong.
i played around with it i.e using mpeg 1 and 2 divx ect
any ideas
gerble1000
it comes up blank
any ideas
gerble1000
There's a bug in the encoder in the latest daily build of FFDSHOW. Dont work for me either.
I don't know which other versions work but I know this one works well: ffdshow-20050303-sse.exe
http://cutka.szm.sk/files/ffdshow-20050303-sse.exe
hi tom
i downloaded this ffdshow
and it works
but the picture quallity is really bad (like blured or wrong resolution or something )ive tried it on the n64
project 64 .
can i ask what settings youve got your ffdshow i.e mpeg2 divx bitrate .
chears
gerble1000
p.s
when i click creat movies i have to also press the start meny button on my keyboard to
get back to windows so i can choose the compression i want to use.
its no bother.just thought id mention it
hi tom
and it works
project 64 .
chears
gerble1000
p.s
The videos are scaled down a lot, to save on space and make things fast. They should look OK when viewed within GameEx as the snap preview is only small. You may get better quality by running the emulator at a higher or lower resolution. You can also adjust the quality the encoder uses, when choosing the compression method. There should be a button there to change settings, then you can adjust the quality or bitrate. Generally a higher bit rate means better quality.
