cnells2000 Posted July 18, 2016 Share Posted July 18, 2016 when i try to load up a rom on gameex for the nes, it now says insert cd. I've never seen that before. how do i make the roms load up normally again? GameEx.ini log.txt Link to comment Share on other sites More sharing options...
RedDog Posted July 18, 2016 Share Posted July 18, 2016 Hi cnells, Check the Advanced Amulator Setup for that emulator and look for the Check for CD/DVD option. It looks like you have it set to Yes for Nes. Change it to No and see if that takes care of it. 1 Link to comment Share on other sites More sharing options...
cnells2000 Posted July 18, 2016 Author Share Posted July 18, 2016 Wow that worked! Thanks man! Also u responded to my other post about future pinball. Did you see the updated reply? Sent from my N9132 using Tapatalk 1 Link to comment Share on other sites More sharing options...
RedDog Posted July 18, 2016 Share Posted July 18, 2016 Good to hear...If you could change the title of this thread to [Resolved] nes section now says insert cd?, that would be great. Yes, I did some testing with Future Pinball today. Please check the other thread. Link to comment Share on other sites More sharing options...
cnells2000 Posted July 18, 2016 Author Share Posted July 18, 2016 How do I change it to resolved? Link to comment Share on other sites More sharing options...
