Hi all,
Just setting up the software side of things for my vp cab, i have set up pinball fx2 in Pinball x and it is working good. I added VP Physmod 5 under other system and copied parameters from Visual PInball. I have all my vp versions in one folder. So the game i am working on is Star Trek TNG. I get it working in Vp out of X all fine but when i launch the game from X i lose the key mappings and my start and plunger buttons change on me. I go back into vp change it, close vp go back into vp.and they stick but as soon as i launch from x it does it again.
Second issue, my dmd goes missing. If i alt tab its there but i just cant bring it back to the front. The only way to get it working in Vp again is to uninstall and re install Vpinmame. I have tried checking and unchecking 'hide dmd' doesnt work.
Couple of little things, i downloaded some system logos for PM5 and VP10 and they look small. Any fix for this?
With backglass images in the frontend is there any quick option to hide the speaker/dmd?
Thanks for the help.
