Screenshot wrong colours.
Guest Archived From Old Forum
Hi,
I've seen this with a couple of NES emus. Not much I can do about it. Only possible suggestion would be to check the colour depth your emulator is running at, if that is an option. Try running it at 32 bit colour. I think what is happening the emulator is running in 8 bit colour, GameEx takes a shot of whatever is on the desktop not the actual directx application, so its using the standard windows colours. If it was in 32 bit or 16 bit this would not be a problem. I think most nes games use 8 bit colour so thats why. If you can use 32 bit colour or possibly even 16 bit colour in the emu I am sure that would do it.
Tom
Everytime I create snaps for my Nes roms folder, the screenshots look
terrible. I use FCEUltra and used the config from this site to get it
to work. When it creates screenshots it messes up the palette of the
screenshot. Please help!
