Is it possible to specify a separate system that uses mostly VP9 configuration but the VPX executable? I'd like to play VPX and VP9 tables using the same PinballX, but so far I haven't been able to put that together. I'm sure I'm missing something, I tried adding it as system to a bunch of files, but it doesn't show up in the systems list.
Hey, thanks, I did search there as well but that didn't turn up. I'll try it next week and will post back how it worked :)
