Maybe this is not really PinballX related so you mods can feel free to delete this post if you want but I'm pretty sure you guys in here know the answer to this so that's why I'm posting this here.
I have mapped my cabinet buttons using X360CE to PinballX and everything is working fine but when I have launched FX2 tables I have no way of exiting the table and getting back to PinballX. I know that the ESC key on the keyboard exits the table but I can't map that with X360CE. Do I need to use Joy2Key or some program like that and map one of the cabinet buttons to the ESC key or is there some way to do it with just X360CE?
Also, which buttons on the Xbox controller are used to scroll through the letters when adding your name to the highscore list? The flipper buttons (left and right trigger on the 360-controller) are clearly not working.
Assuming your controller emulates a joypad then, yes, you will need another program to map exit emulator.
I noticed that flippers buttons no longer scroll through the letters. Used to work that way, but I guess something changed with Pinball FX2. I have not gotten around to trying to fix that issue on my cab yet.
