Priority of PinballX Startup audio vs Table audio clips
I just started using the Table audio feature (which is a great feature by the way) and I noticed that when I start PinballX, if the first table has Table Audio file, it plays that table audio, instead of playing the "Pinball Wizard" mp3 startup audio.
Also if you continue browsing tables, either the table audio plays or if no table audio available, it plays the Pinball Wizard audio, until it gets interrupted by another table audio clip.  So you end up hearing bit and pieces of the Pinball Wizard mp3 while browsing tables until it has completed playing
Workaround is to disable the Pinball Wizard startup audio, but actually I would prefer to hear the Pinball Wizard startup audio to completion, before hearing any table audio clips (even if I am browsing).
