I've gone through the forums and thankfully I finally got it working fine. There is one thing that I would like to know for future reference. I can get the games to load when I add the extension .lnk after [ROMPATH] like [ROMPATH].lnk.
TaitoSC is just the shortcut file the SFIV.lnk is located
but if for whatever reason I had more then one extension I would assume it would not work. any help would be appreciated. thank you
the .map file
SFIV.lnk|SFIV
console window after trying you can see no extension
F:\GameEx>F:
F:\GameEx>CD "F:\Taito Type X\Roms\ArcadePC Loader\TaitoSC"
ECHO is on.
"F:\Taito Type X\Roms\ArcadePC Loader\TaitoSC\SFIV"
ECHO is on.
F:\Taito Type X\Roms\ArcadePC Loader\TaitoSC>PAUSE
Press any key to continue . . .
[Emulator_1]
PlayMusic=False
Debug=True
ShowDesktop=True
MapKeys=True
ManualPath=
CartPath=
BoxPath=
TitlePath=
SnapPath=
Command="[ROMPATH]\[ROMFILE]"
RomPath=F:\Taito Type X\Roms\ArcadePC Loader\TaitoSC
WorkingPath=F:\Taito Type X\Roms\ArcadePC Loader\TaitoSC
StartPageLogo=Capcom
TITLETEXT=Taito Type X
STARTPAGENAME=[Arcade] Arcade Taito Type X
lastgame=
DATABASE=
ReplaceDash=False
MAPFile=F:\GameEx\MAP FILES\[Arcade] Arcade (Taito Type X).map
configFile=Taito
CustomBackground=
ControlPanelPath=
ReplaceUnder=False
Capitals=False
RemoveBrackets=False
DontShowInfo=False
PlayInScreenSaver=False
ShowMostPlayed=False
RandomMostPlayed=False
PlaySelectionMusic=False
ROMFilter=*.lnk
Never used a MAP file for lnk files. Not sure why you are, it's a shortcut and you can name it anything you like. :)
That being said, your map is probably the issue? It's been a minute since I manually made one, but dies it will without that?
I'll be damned that was it. I just assumed you had to create one. this is the first emulator I setup in game ex besides mame of course. and no it's the first is path, second is name, unless we are talking about something different. I tried to modify the second one and it modified my name to .lnk, not sure if that's what your supposed to do though.
thank you very much.
