Is there a setting in Game EX to turn the volume for the intro video down or off?
I like the ambiance playing and the video makes everything sound jumbled...
I looked through the forums and did not find the answer (unless I missed it)...
Thanks.
How did you set an intro video? Which video is it that you're using? I'm having a problem setting an intro video (I have the option turned on), so if you have it running, it must work somehow.
Thanks.
Jim
MrScary.. if you have the ability to, try and edit the video, cut out the audio track, and resave it. If it's in a format other than avi or mpeg, you might have trouble. Check out www.videohelp.com for tools and such.
Thanks.
Not for the intro video, but you can turn off the sound for the snap/preview videos via the "Audio in Snap AVi's" setting under Audio settings
