I have two lists showing in game manager and in pinballx dobble games. If I look in pinballx log it loads twice. In game manager I could disable the games in one or the other list and it results in the table not showing at all. If I go to the database directory it only has one pinball arcade folder and in the folder one xml. Any ideas let me know.
PinballX.ini
You have System_2 assigned to "Pinball Arcade"  and it is enabled. It uses the NukePA launcher.
You also have the Pinball X built in support for "PinballArcade" enabled. If you have an xml database set up for both systems then Pinball X will display all of the games in your main wheel.
Pick one system and disable the other. You would do this using the Settings Wizard and not Game Manager.
