Your log file shows an OutOfMemoryException around the time the listinfo.dat file was being processed. It appears that your PC ran out of memory. I have a feeling that the process is stalling and GameEx is timing out. Your PC only has 2 Gigs of RAM, and while that is more than the 1 Gig requirement that Windows 7/10 suggest for a 32 bit system, I have generally considered 4 Gigs to be a more reasonable minimum.
I would suggest doing a clean boot, closing out any unnessessary programs, and then try running the update again. If the same exception occurs again, you might consider upgrading the RAM (unless someone else has another suggestion, of course). :)
I also did a gameslist update on my Windows 7/GameEx 14.43 machine and it did work fine. However, it does not necessarily rule out a problem related to 14.43.
Hi Reddog!!
I can't update the RAM memory because it's a tablet pc.
There is no other solution to this problem?
Thanks un advance
Hey Evil,
Did you try my suggestion of doing a clean boot and closing out any other programs?
Thanks Reddog!!!
It works!!!
