Hi !
I've a strange Problem with my 2.12 installation. Everything works fine until yesterday. Suddenly the menu for starting the selected table or change the list does not appear anymore. I hear the sound and can navigate 'blind' trough the options. The 'exit' menu appears without any problem. I reinstalle the lav-filters and even pbx, i tried different settings like disabling pinmame and b2s support, nothing worked. I tried to shrink my table-list to only a few tables...nothing worked.I'm not sure what i've done before the error occured,i remember i added some table sounds but this sould have nothing to do with any display issues i guess ☺
Maybe anyone had the same Problem and fixed it ??
See ya....jas
Hmm..i found a not too old backup of my .ini ...with this ini all works fine again. I compared the buggy version with the workings one and found no big differences...
