I use an X-arcade controller upgraded with a zeb analog nudge controller unfortunately the x-arcade controller emulates keyboard keys and none are "esc" or "enter" and Pinball FX2 doesn't let you remap those two menu functions. So tho i can play with the controller navigating menu's requires the keyboard.
What I would like to do is remap the keyboard 1 key to esc and keyboard 2 key to enter when launching Pinball FX2 with PinballX and return to normal when exiting the PBFX2 games.
Is anything like this remotely possible..with a third party program or anything?
My Google-Fu hasn't led me to a utility that toggles on and off keyboard key assignments.
Any clues advice or ideas would be greatly appreciated.
ok I downloaded autohotkey and read thru the basics and figured out how to get it to work the way i want.
Below is the autohotkey script parts i added to the default new script then i compiled into an exe.
I setup the launch before to run the compiled script and the script auto kills itself when i hit the key to end emulation and return to pinballx I use.
Overall alot easier then I feared it would be.
So any X-arcade users or keyboard controller pincab users that want to do something like this, this seems easiest way to deal with it.
I found you must use caps for Esc and Enter for it to work and Tab is only needed if you want to navigate the leaderboards
] is key i use to quit back to PinballX
Script file:
#NoEnv ; Recommended for performance and compatibility with future AutoHotkey releases.
; #Warn ; Enable warnings to assist with detecting common errors.
SendMode Input ; Recommended for new scripts due to its superior speed and reliability.
SetWorkingDir %A_ScriptDir% ; Ensures a consistent starting directory.
1::ESC
2::ENTER
5::TAB
]::ExitApp
