There is a command line so I do epsxe emulator enable multi-tap user function when it is started?
I searched the Internet and found several command lines this emulator, but none of that solves this problem of mine. :(
reason: When the game is over 2 player multi-tap must be enabled. And when the game is up to 2 players the multi-tap needs to be disabled.
If you are unlike those settings do not work the controls. I wanted to create two folders epsxe emulator, and within GameEx, I would add the command to multi-tap activation in one of two command lines. This is originally my plan.
GameEx.ini
PLAYSTATION (4 JOGADORES).ini
About this my doubt in this post, I asked the same question in another forum. The person replied that:
"there is the direct commandlineswitch to enable Multitab. But its possible to set ePSXe's registryentrys by the windowsconsoles Reg-command. "
That same person gave me a file containing this command line. It sent me a file called "ePSXe_Multitap.cmd"
The same held this command:
pushd::enable MultitabREG ADD "HKCU\Software\epsxe\config" /f /v "Multitap1" /t REG_DWORD /d  "1"REG ADD "HKCU\Software\epsxe\config" /f /v "Multitap2" /t REG_DWORD /d  "1"::run ePSXeePSXe %*::disable MultitapREG ADD "HKCU\Software\epsxe\config" /f /v "Multitap1" /t REG_DWORD /d  "0"REG ADD "HKCU\Software\epsxe\config" /f /v "Multitap2" /t REG_DWORD /d  "0"
I do not quite understand what this command does exactly. Or how to use it.I ask forum again. The answer I give so is answered. If anyone here in this forum knows anything about it please help me. :huh:
It adds a setting to the registry to enable/disable multitap in there by default I think.
As I do not practice in the programming branch I was a little confused.
Adultery please tell me if I'm wrong.
If I want to use a command to activate the multi-tap the record I will use exactly is command line in a file with extension .CMD
And if I want to disable the registration multitap will use this line:
It's correct?? I ask this because the controls look very different. :huh:
