Hello,
first of all sorry for my bad english, I am from Germany.
I used to play with my Pincab very often. PinballX allways worked very well.
But now I have a (big?) problem. Everytime I boot my machine up, PinballX starts directly (Autostart).
The first table I load is usualy working. When I exit that table (going back to the PinballX-Wheel) and choose another (or the same table), it tries to load up. I can see that table for about half a second, then PinballX exits automatically and goes back to the Wheel-Menu.
If I start Visual Pinball directly (without PinballX), everything is working correct.
I allready tried to remove and reinstall PinballX, but the problem is still there...
Here are my logs:
l14:53:07.4  20.11.2015:  PinballX - Version 2.0614:53:07.4  20.11.2015:  Windows 7 Ultimate Service Pack 1 64-Bit (7,953125GB)14:53:07.4  20.11.2015:  Loading Settings14:53:07.4  20.11.2015:  Initialize Component14:53:07.4  20.11.2015:  Initialize Display14:53:08.6  20.11.2015:  Loading PlugIns14:53:08.7  20.11.2015:  Created DirectX BackGlass Window14:53:08.8  20.11.2015:  Hiding Cursor14:53:08.8  20.11.2015:  Hiding Taskbar14:53:08.8  20.11.2015:  PinDMD2 Intialized14:53:08.8  20.11.2015:  CPU: Intel(R) Pentium(R) CPU G2020 @ 2.90GHz14:53:08.8  20.11.2015:  GPU 1: NVIDIA GeForce GTX 660  14:53:08.8  20.11.2015:  Displays: 214:53:08.8  20.11.2015:  Load Game List14:53:08.8  20.11.2015:  Loading Database: Visual Pinball14:53:08.9  20.11.2015:  Finding and matching artwork and videos14:53:08.9  20.11.2015:  Loading Game Statistics and Scores14:53:09.7  20.11.2015:  Main display running full screen windowed.14:53:09.7  20.11.2015:  Loading Surfaces14:53:09.9  20.11.2015:  Finished Loading Surfaces14:53:09.9  20.11.2015:  Initialize Audio14:53:10.0  20.11.2015:  Set Keyboard Controls14:53:10.0  20.11.2015:  Initialize Joystick14:53:10.0  20.11.2015:  1 Joystick Attached14:53:10.0  20.11.2015:  Started14:53:15.0  20.11.2015:  Launch System14:53:15.0  20.11.2015:  Waiting for threads14:53:15.1  20.11.2015:  Disposing display14:53:16.5  20.11.2015:  C:\Program Files (x86)\Visual Pinball\VPinball990-RC1.exe /play -"C:\Program Files (x86)\Visual Pinball\Tables\Back_to_the_Future_NightMod_LoadedWeapon.vpt"14:53:16.5  20.11.2015:  C:\PinballX\vpauto.exe 14:53:22.9  20.11.2015:  Hidden Visual Pinball Editor Window14:53:23.5  20.11.2015:  Exit System Control Pressed14:53:26.5  20.11.2015:  Created DirectX BackGlass Window14:53:26.5  20.11.2015:  PinDMD2 Intialized14:53:26.6  20.11.2015:  Main display running full screen windowed.14:53:32.9  20.11.2015:  Exiting14:53:32.9  20.11.2015:  Showing Taskbar14:53:32.9  20.11.2015:  Unhiding Mouse Cursor14:53:32.9  20.11.2015:  Disposing Plugins14:53:32.9  20.11.2015:  Saving Settings14:53:32.9  20.11.2015:  Bye
It says "Exit System Control Pressed", but I didn't...
Here is my Config-file:
[Display]Monitor=0rotate=270Windowed=FalseWindowWidth=480WindowHeight=720WindowX=0WindowY=65PlayFieldBrightness=230WheelTextColor=ffffffffWheelTextOutlineColor=ff000000InfoTextColor=ffffffffInfoTextOutlineColor=ff000000FilterTextColor=ffffffffFilterTextOutlineColor=ff000000MenuColor=ffffa500[BackGlass]monitor=1x=0y=0width=1920height=1080[DMD]Enabled=Truemonitor=2x=0y=0width=900height=300AutoPositionPinMAME=TrueHidePinMAME=TrueUsePinMAME=True[FileSystem]EnableFileMatching=True[Interface]DesktopModeEnabled=FalseEnableAdditionalDetail=TrueShowSystem=TrueShowRatings=True[Audio]StreamVolume=100SampleVolume=100PlaySoundInVideos=True[Startup]playsound=Falseplayvideo=FalseStartWithWindows=Yes[KeyCodes]quit=27left=160right=161select=13rotate=82pageleft=33pageright=34exitemulator=27ingame=80screenshot=83screenshotbackglass=66instructions=73volumedown=109volumeup=107[JoyCodes]quit=left=0right=1select=2rotate=3pageleft=4pageright=5exitemulator=ingame=13instructions=14[Text]Line1=Free PlayLine2=Press StartFeaturing=FeaturingTables=TablesPlayGame=Play GameInstructions=InstructionsInformation=InformationFlyer=FlyerGameplay=GameplayTutorial=TutorialExitGame=Exit GameReturnToGame=Return to GameReturn=ReturnExit=ExitShutdown=Shutdown[FuturePinball]Enabled=FalseWorkingPath=h:\-PINBALL-\-FUTURE PINBALL-TablePath=h:\-PINBALL-\-FUTURE PINBALL-\TablesExecutable=Future Pinball.exeParameters=/open "[TABLEPATH]\[TABLEFILE]" /play /exit /arcaderenderLaunchBeforeEnabled=falseLaunchBeforeWorkingPath=LaunchBeforeExecutable=notepad.exeLaunchBeforeHideWindow=FalseLaunchBeforeWaitForExit=TrueLaunchAfterEnabled=FalseLaunchAfterWorkingPath=LaunchAfterExecutable=notepad.exeLaunchAfterHideWindow=FalseLaunchAfterWaitForExit=TrueMouseClickFocus=True[VisualPinball]Enabled=TrueWorkingPath=C:\Program Files (x86)\Visual PinballTablePath=C:\Program Files (x86)\Visual Pinball\TablesExecutable=VPinball990-RC1.exeParameters=/play -"[TABLEPATH]\[TABLEFILE]"LaunchBeforeEnabled=falseLaunchBeforeWorkingPath=LaunchBeforeExecutable=notepad.exeLaunchBeforeHideWindow=FalseLaunchBeforeWaitForExit=TrueLaunchAfterEnabled=FalseLaunchAfterWorkingPath=LaunchAfterExecutable=notepad.exeLaunchAfterHideWindow=FalseLaunchAfterWaitForExit=True[ExitScreen]Enabled=TrueEnableExit=TrueEnableShutdown=True[StartupProgram]Enabled=falseWorkingPath=Executable=notepad.exeParamaters=HideWindow=trueWaitForExit=false[ExitProgram]Enabled=falseWorkingPath=Executable=notepad.exeParamaters=HideWindow=FalseWaitForExit=[AttractMode]Enabled=TrueTimer=1ShowFor=15MuteAudio=False[System_1]Name=MAMEEnabled=FalseWorkingPath=C:\- EMULATORS -\- MAME -TablePath=C:\Executable=mamep64.exeParameters=[TABLEFILE]SystemType=0[AutoExit]Enabled=FalseMinutes=10[Login]Enabled=False[PinballFX2]Enabled=FalseWorkingPath=C:\Program Files (x86)\SteamExecutable=steam.exeParameters=-applaunch 226980Process=Pinball FX2.exeWaitFor=20[Internal]lastwheelcachematchsize=-1123lastselected=Back_to_the_Future_NightModBack_to_the_Future_NightMod_LoadedWeaponVisualPinballfilter_year=filter_company=filter_custom=filtername=Tables[SetupWizard]EmuPath1=C:\EmulatorsAssetPath1=C:\AssetsRomPath1=C:\RomsDefaultPathPrompt=TrueDownloadDatabasePrompt=TrueDownloadEmulatorPrompt=TrueWizardMode=1CustomArray=SearchArray=SavePosition=FalseSectionIndex=9SearchText=EmulatorIndex=0EmulatorGroupIndex=0DaphneIndex=0HTMLAppsIndex=0ExternalAppsIndex=0RadioStationsIndex=0NewsFeedsIndex=0MappedDrivesIndex=0SystemIndex=0ShowPanel=TrueFontSize=1WindowState=0WindowSize=650,478WindowLocation=2296,411[GameListManager]onlinemode=false
Hope you guys can help me, this is really terrible for me :(
Thanks in advance and greets grom Germany.
M4ttes
