After my auto update to 6.20 today, I'm usable to start up GameEx for some reason. Can anyone help me get my favorite front end back up and running?
Thanks. :)
Application has generated an exception that could not be handled.
Process id=0x5ac (1452), Thread id=0xc18 (3096)
Same thing for me. It only happens when I reboot and Game Ex Auto starts. Then after closing the error and starting Game Ex up again, it works.
Not for me... :( Can't use it at all.
thats what i did tho i copyed my old .ini over and i get an error as well
ill try installing it again and try other things it might be a user error something i forgot.
Edit:
ok found out it was my backuped .ini there gave me that error so i just edit the new .ini and i guess as would be fine :)
Are you saying you have exactly the same issue as Adultry?
sorry no a different code in the error window :
Process id=0xab0 (2736), tread id=0x2bc (700)
have you tried the latest version, released a few hours ago?
Can you also post the log, if there is a current one.
The version you just put out seems to have fixed the error... Or at least the manual donload of the program did the trick. Thanks again! :)
oh didnt notice there was a 6.27 version it works fine now thx Tom :)
