My control panel has a pause button as an admin button up top.. In pinball x I set "p" as my exit emulator button so whenever I push my p/pause button it just kills visual pinball. I also disabled exit in visual pinball to case anyone his the escape key in the panel it doesn't go to the stupid editor menu. If you aren't using pinball x u can change your gamex exit key to something besides exit, since visual pinball uses exit by default to take u to the visual pinball menu. Annoying as hell and took me a while to get everything to work smooth using just a control panel
Hi Aldub516
Thank-you for your input. I was hoping there was a setting in VP that could have it exit without going into the editor. I don't really want to change the way Gameex handles every emulator. It seems that this will be the only way to exit in Gameex. I do have a Pinballx set up and I may use that for a Pinball only set up but I was hoping Gameex could do everything smoothly.
Thanks for your help.
